> popping noise, i hear something
post Mar 27, 2007 - 5:10 PM
jdmart
Joined Mar 7, '07
From dallas texas
ok its not a real problem but now its getting annoying! every time i shift gears i hear like this popping noise coming from my exhaust even at low rpms. Sometimes i doesnt happen, keep in mind i have 2.25 ehaust piping and a aftermarket catback could it be backpressure problems and will it harm my hp? ur advice is apreciated-thnx
DRIVE UP..........
ACCEPT THE CHALLENGE.........
DESTROY YOUR OPPONENT.........
Replies (1 - 6)
post Mar 27, 2007 - 8:07 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
You can try checking your timing if it's to factory spec. If it is, then it could be just your exhaust setup. Well, I got the popping also but performance hasn't gotten bad or anything. I'm pretty sure it's normal with an aftermarket exhaust.
This post has been edited by netrata: Mar 27, 2007 - 8:25 PM
post Mar 30, 2007 - 3:04 PM
Bling-bling
Joined Mar 11, '07
From Brisane, QLD Australia
yeah i got popping noise too but i have a catless exhaust. sometimes its really loud like backfire.
my car is running fine so i think its normal.
post Mar 30, 2007 - 11:41 PM
jdmart
Joined Mar 7, '07
From dallas texas
QUOTE(Bling-bling @ Mar 30, 2007 - 8:04 PM) [snapback]541518[/snapback]
thnx for the info plus how did u go catless? do u have a header installed?
DRIVE UP..........
post Mar 31, 2007 - 5:43 PM
alltracman78
Joined Aug 9, '06
From Ma
Most likely a backfire.
Unburned fuel getting combusted in the exhaust.
If that's the case, either you're not getting full combustion in the chamber or you are running a tad bit rich.
post Apr 2, 2007 - 9:33 AM
Bling-bling
Joined Mar 11, '07
Nah my car just has a stock header. i think to go catless u just replace the catalytic converter with a piece of exhaust pipe.
post Apr 2, 2007 - 9:36 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Then you would still have a cat, because there is one on the exhaust manifold as well as along the piping.
I have this happen every once in a while with my exhaust setup, and I have both cats still! The last time was a few months ago, but I remember when I heard the pop from the exhaust, I felt it in the pedals as well. Very strange, but it doesn't bother me. I just love the rumble!
This post has been edited by 95CelicaST: Apr 2, 2007 - 9:39 AM
**** Photobucket
Lo-Fi Version Time is now: January 10th, 2025 - 3:06 PM
