> Install Boost Controller - Dual Port
post Apr 6, 2007 - 6:35 AM
swerve
Joined Mar 18, '06
From Brisbane - Australia
Hi Guys,
Installing a new electronic boost controller. Now, every one says it is the easiest thing, and I am sure I must have missed something simple.
On the CT-26 the are 2 ports coming off the wastegate actuator. One has a hose from the turbo and the other from the intake manifold. All images I can find for the installs on the net only have the one port.
Are both of these ports to be connected to the boost controller or is one port an in and the other an out?
Thanks
Replies (1 - 5)
post Apr 6, 2007 - 7:12 AM
The controller goes in between the compressor & wg actuator. You can hook the pressure sensor to the intake mani tubing.
post Apr 6, 2007 - 7:36 AM
swerve
Joined Mar 18, '06
QUOTE(Supersprynt @ Apr 6, 2007 - 10:12 PM) [snapback]543882[/snapback]
ok got the first bit. So i use the port that has the hose from the compressor. When does the other port from the actuator go to?
post Apr 6, 2007 - 8:29 AM
Gary
Joined Aug 28, '04
From FLA USA
The other port on the actuator need to be disconnected and capped.
_Gary
post Apr 6, 2007 - 1:49 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(Gary @ Apr 6, 2007 - 6:29 AM) [snapback]543893[/snapback]
Bingo. Remove that vacuum line and cap the extra connection on the wastegate actuator and the hardline that the hose used to go to.
Then just hook up the boost controller between the turbo and the wastegate, following the correct "in" and "out" ports (see your boost controller documentation for that).
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 6, 2007 - 3:43 PM
swerve
Joined Mar 18, '06
Awesome, thanks guys.
Hopefully won't oveboost anything today. lol
Lo-Fi Version Time is now: November 27th, 2024 - 1:33 PM
