> lack of heat, 95 celica GT 1.8l
post Apr 8, 2007 - 2:06 PM
Xero
Joined Dec 17, '06
From Grand Rapids Michigan
I have replaced the thermostat, rinsed out the engine, the heater core and the radiator. Have even heated up the thermostat in hot water to make sure that it opens. The upper radiator hose gets hot soon and the lower quite awhile later. The heater hoses are hot, but no heat. I even took out the control valve out of the heater hose line and checked that it worked. Could it be something electrical?
This post has been edited by Xero: Apr 8, 2007 - 2:08 PM
Replies (1 - 4)
post Apr 8, 2007 - 2:11 PM
Does your car blow air when you turn on the fan? Does it just blow cool air? If so, it's not electrical. I trust that you've properly bled the cooling system?
post Apr 8, 2007 - 5:46 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
Check the cables behind the control pannel (for the heat and AC). Also it could be electric so check the servo motor there are two on the drivers side inside the dash the one on top behind the instrument panel is the inlet motor the lower one is the outlet motor. The way to check it is to put a ground to one terminal and battery voltage to the other and if it moves it's good. You can switch the terminals to check that it can move the other direction.
post Apr 8, 2007 - 6:44 PM
Culpable04
Joined Apr 17, '06
From New Jersey
post Apr 9, 2007 - 7:39 AM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
i had this prob. under the drivers right side panel by your gas pedal, look under there and see if your blue wire (climate control for heat/cool) is off its latch. i did this and figured it out after teh cold part of winter was over.
Lo-Fi Version Time is now: February 23rd, 2025 - 8:12 AM
