> best way to penetrate through metal?, needa drill a hole through the metal of the celica
post Apr 9, 2007 - 3:46 AM
daazndood
Joined Jun 5, '06
From Hayward,CA
hey guys. unfortunetly, my 404 rear lip doesnt line up exactly with my rear bumper. the end of the lip, where you drill the holes to screw onto the car, isnt long enough to reach the predrilled holes in the cars wheel well. so i need to drill new holes a little closer to the side in order to screw on my lip.
i've noticed that this part of the car is made of metal. im having a hard time making a hole through this. any tips for me?
its the part in the wheel well of the rear wheels. on stock celicas, it has this rubber thingy. its opposite of the area where the side skirts screw on.
Replies (1 - 19)
post Apr 9, 2007 - 5:16 AM
ummmmmmm maybe a drill??
post Apr 9, 2007 - 10:13 AM
lol yea use a drill dude....black oxide bit is good stuff
post Apr 9, 2007 - 5:11 PM
daazndood
Joined Jun 5, '06
From Hayward,CA
haha. i forgot to mention that i cant drill through it for some reason. the drill would just keep going and going but not go anywehre.
post Apr 9, 2007 - 5:25 PM
thats cause u are using the wrong bits and/or drill
get better bits...
and u can't say it won't cause i've drilled every part on a celica
post Apr 9, 2007 - 6:09 PM
QUOTE(daazndood @ Apr 9, 2007 - 6:11 PM) [snapback]544900[/snapback]
time for some new bits.
drill bits are consumable items, they do not stay sharp forever. once they stop drilling so good, you replace them. wink.gif
post Apr 9, 2007 - 6:25 PM
uberschall
Joined Jul 29, '03
From north of detroit
invest in a center punch too. that way you can precisely mark where you want to drill, and help keep the drill bit from walking on you.
do you know who i am, mr. worley?
post Apr 9, 2007 - 7:36 PM
97lestyousay
Joined Jul 7, '03
QUOTE(playr158 @ Apr 9, 2007 - 3:25 PM) [snapback]544905[/snapback]
How about a spring?
Crankshaft journal?
axle shaft? I'm sure I can think of more if I try. ha ha
JDM guy made me do it.
post Apr 9, 2007 - 7:53 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
...is the drill in reverse? (when u pull the trigger, does the bit spin counter clockwise or clockwise?)
Kawi Love
post Apr 9, 2007 - 8:40 PM
QUOTE(devilsden97 @ Apr 9, 2007 - 8:53 PM) [snapback]544982[/snapback]
post Apr 9, 2007 - 9:06 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(playr158 @ Apr 9, 2007 - 9:40 PM) [snapback]545002[/snapback]
laugh.gif laugh.gif tongue.gif thats awesome.
post Apr 9, 2007 - 9:58 PM
97lestyousay
Joined Jul 7, '03
Is the bit tight, or is it spinning in the chuck?
post Apr 9, 2007 - 10:10 PM
daazndood
Joined Jun 5, '06
From Hayward,CA
yea, its tight and its going in the right direction. i guess the drill isnt strong and /or sharp enough to go through the metal. its a pretty basic electric drill so im guessing its too weak
post Apr 9, 2007 - 10:13 PM
devilsden97
Joined Jun 13, '05
when u say "basic" do u mean cordless....or one that plugs into the wall (aka corded, i just think that sounds stupid..."a corded drill") if its cordless how many volts?
Kawi Love
post Apr 9, 2007 - 10:39 PM
daazndood
Joined Jun 5, '06
From Hayward,CA
its cordless, but i dont remember how many volts it is. its not on me right now, becuase im visiting home till tomarrow. it is lower end though. even drilling through the fiberglass lip wasnt so easy for it.
post Apr 9, 2007 - 10:42 PM
devilsden97
Joined Jun 13, '05
QUOTE(daazndood @ Apr 9, 2007 - 11:39 PM) [snapback]545046[/snapback]
if i drill metal i ALWAYS use a drill that plugs into the wall. If im forced to use a cordless i try to get a higher voltage one, and use the higher torque setting. (they usually all have a switch for 1)speed 2) torque) then I use light to medium pressure and just let the bit do all the work...some kind of lubricant can also make it easier on the drill, so that its not binding as much. Good luck bro.
edit: also, try a smaller drill bit first, then go up in size untill u get to your desired diameter...less metal removed per bit...little easier on the drill.
This post has been edited by devilsden97: Apr 9, 2007 - 10:45 PM
Kawi Love
post Apr 9, 2007 - 10:59 PM
daazndood
Joined Jun 5, '06
From Hayward,CA
yeah my dad told me it would be alot weaker then a corded drill. i guess i gotta go look for a corded drill now. or a stronger cordless?
thanks though everyone!
post Apr 9, 2007 - 11:03 PM
devilsden97
Joined Jun 13, '05
QUOTE(daazndood @ Apr 9, 2007 - 11:59 PM) [snapback]545059[/snapback]
stronger cordless will do it....i try not to use lower then an 18v cordless on metal.
Kawi Love
post Apr 9, 2007 - 11:12 PM
97lestyousay
Joined Jul 7, '03
There is nothing real technical about it, as Manny said originally
the bit is toast. I have a cheap cordless that will buzz right thru
a body panel no problem with a good bit. I usually vari the pressure
until I find what works best.
post Apr 10, 2007 - 2:27 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
Dumb question: why is higher voltage better? When I was shopping for a drill I was going to go with a 18v drill that had a speed of 0-400/1300 rpm or something and ~280 ft lbs.
I opted for a 14.4v impact wrench with a drill adapter that puts out 2300 max rpm and 1050 ft lbs.
Even though the impact wrench/drill has less voltage, it has a drill adapter, faster speed speed, and 3x the tq wouldnt it be better? Does a regular drill do anything that I wouldnt be able to do? Wouldnt tq be one of the more important things for a drill to have?
This post has been edited by 6gsillyca: Apr 10, 2007 - 2:33 AM
Lo-Fi Version Time is now: December 14th, 2025 - 4:31 PM
