> performance for 5S-FE?, I'm trying to find some performance parts for the 5S-Fe. I know GR
post Apr 16, 2007 - 9:20 AM
NapTown94
Joined Jan 19, '07
From Indianapolis
[color=#FF9900] so I'm trying to find some performance parts for the 5S-Fe that I'm going to drop into my 94 St coupe. i have found an exhuast by GReddy, but I'm already having a custom exhaust done. What else do they make for the car? anyone got any parts for sale?
Replies (1 - 19)
post Apr 16, 2007 - 11:01 AM
Negative
Joined Apr 28, '04
From Houston, Texas
If you have an ST and haven't swapped you have a 7A-FE not a 5S-FE.
post Apr 16, 2007 - 11:13 AM
96bluevert
Joined Mar 19, '07
From Washington
I think he has already swapped/ going to soon because it says on his profile "5SFE in a couple of weeks". so that is probably why he's asking about performance for the 5SFE motor.
As for your question naptown, i'm not sure specifically. havn't really looked into performance parts much. but i know there are of course different intakes and exhausts and turbos you can get for our cars. i guess i'm kind of curious what would be good perfomance for the 5S as well.
post Apr 16, 2007 - 12:46 PM
NapTown94
Joined Jan 19, '07
From Indianapolis
yeah, my 7A-FE died. so I'm swapping in a 5S-FE. I was going to try and build it out a little before I have it put into the car. I can't turbo for a while. so I need all-motor mods.
post Apr 16, 2007 - 1:06 PM
what year/obd spec/emissions spec is the 5sfe? theres plenty of stuff you can do thats all been talked about here before. search and you shall find!
post Apr 16, 2007 - 1:08 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
usual stuff, intake, header, exhaust...turbo, nos, etc
post Apr 16, 2007 - 3:16 PM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
put some bitchn stickers on the car
those always make it faster
post Apr 16, 2007 - 3:20 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
^ yeah get some TRD stickers and 6GC stickers. You'll gain atleast 25 hourse for each. I don't know how pulleys perform on the 5sfe, you should try them. Headers Intake Safc and some injectors.
This post has been edited by bccentaur3: Apr 16, 2007 - 3:22 PM
94 Celica gt white (sold)
post Apr 16, 2007 - 3:29 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Why go through the headache of an A to S series swap for a 5S? Swap a 3SGTE if you're going that way, or keep with the A series to save money and time. 4AGE or GZE. Woot!
BUT if you must go 7A to 5S I would get intake, header, exhaust, SAFC and injectors.
EDIT : stickers are good too. My two 6GC stickers helped me run the 4 min 1320. tongue.gif
This post has been edited by 95CelicaST: Apr 16, 2007 - 3:30 PM
**** Photobucket
post Apr 16, 2007 - 3:43 PM
LewFX
Joined Jan 28, '05
are you guys trying to help my sticker sales or bash me, i cant tell by the sarcasm!
post Apr 16, 2007 - 3:46 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Sarcasm bro. Oh fyi I'll be ordering the stickers soon if you still got them. wink.gif
95CelicaST
Joined Feb 5, '05
But for the record, Lew's vinyl stickers are excellent quality and value, plus he is a great guy to do business with. smile.gif
**** Photobucket
post Apr 16, 2007 - 4:04 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Build it for strength but don't drop the compression - then later when you have the money follow Pressure2's 5S-FTE build guide and then you will have a fast car that was worth the A to S series swap.
post Apr 16, 2007 - 4:45 PM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
QUOTE(LewFX @ Apr 16, 2007 - 3:43 PM) [snapback]547334[/snapback]
i love your stickers
but i was basing other stickers like flames and APC stickers...
post Apr 16, 2007 - 9:00 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
QUOTE(spolski07 @ Apr 16, 2007 - 4:45 PM) [snapback]547352[/snapback]
post Apr 16, 2007 - 9:29 PM
LewFX
Joined Jan 28, '05
of course i got stickers left
post Apr 17, 2007 - 12:36 AM
6strngs
Joined May 12, '06
From Wilmington, NC
the only way for any real amount of power for the 5sfe is a turbo. there are threads in the stickies if you want to learn about that. otherwise:
Intake: either an injen short ram intake, or read the sticky about how to make a custom cold-air intake out of an accord intake
header: http://www.1supertoyota.com/products/rd10.htm
exhaust: greddy used to make a cat-back, but it's discontinued and a little hard to find. probably better off with a custom one.
camshafts: webcam racing is the only place I've found that makes any. but I've heard there are some other places that do. doing a search over at mr2oc.com might bring some more information.
underdrive pulley: unorthodox racing makes a lightened crank pulley, but I've heard this can shorten the life of the motor.
clutch: there's a couple that make them. I got a SPEC stage 2 and I haven't had any problems, but some other people say they have. people generally praise ACT clutches for our celica, so maybe stick with one of those.
flywheel: fidanza or clutch masters. I got a fidanza and I love it, it made a big difference.
Radiator: koyo makes an aluminum radiator. I got it, and I noticed no difference. I don't think it's worth it.
that's about all I can thin of right now. but seriously, even if you did all these mods, you probably won't see more than 10-15 horsepower, except for the cams, I've heard they make a pretty big difference for a 5sfe because of how restrictive the stock ones are. but you won't be getting more than 140-150 whp without a turbo or NOS.
post Apr 17, 2007 - 1:12 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
"5SFE" and "performance" hardly go together... unless in conjunction with "turbo"...
post Apr 17, 2007 - 12:50 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Kwanza26 @ Apr 17, 2007 - 2:12 AM) [snapback]547547[/snapback]
It's all about being class specific. Last year the National Champion in the STS class of Solo II AutoX won with a KA24DE. I'd say the KA24DE and the 5SFE are comparable. 5SFE will never be a drag motor or an all out race motor, but I still love mine. And mine is almost completely stock.
Live Free, Be Happy
post Apr 17, 2007 - 3:09 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Bigmeanbulldog55 @ Apr 17, 2007 - 10:50 AM) [snapback]547659[/snapback]
I'll second that. my friend has a 91 240sx with the KA24DE and our cars are pretty much dead even.
Lo-Fi Version Time is now: November 29th, 2024 - 10:46 PM
