vibrateing stearing wheel??? |
Apr 23, 2007 - 1:27 PM |
Enthusiast Joined Apr 19, '07 From Dayton, Ohio Currently Offline Reputation: 7 (100%) |
my steering wheel shakes/ vibrates when im going 65mph or higher. and ideas on how to fix this?
Apr 23, 2007 - 1:30 PM |
Enthusiast Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
balance your tires if they are too old probably time to get new ones.
Apr 23, 2007 - 1:47 PM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
Tires are not balanced....usally it will start after about 45 MPH...
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
Apr 23, 2007 - 1:51 PM |
QUOTE(Daftboy @ Apr 23, 2007 - 1:47 PM) [snapback]549666[/snapback] Tires are not balanced....usally it will start after about 45 MPH... my tires are way off balance they are old so not even worthy to re balance them and I can go to 70 MPH with no vibration after that it gets crazy. -------------------- |
Apr 23, 2007 - 1:57 PM |
lol...thats how mine kinda are....I have snow tires in the rear 205-55-15
Then In the front left I have a new tire at 205-55-15 And for the front right I havea old tire at 195-50-15 and 3 of them have flat spots..... This post has been edited by Daftboy: Apr 23, 2007 - 1:57 PM -------------------- --------------------------------私は銀行に漂う,TRD Inspired |
Apr 23, 2007 - 2:02 PM |
Enthusiast Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) |
mine does that too, i got my tires rebalanced, i think i got another year of thread left....hmmm
Apr 23, 2007 - 2:19 PM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
also check your P/S belt. I had the same problem b4, got my tired balanced, still was happening. then i blew my head and while it was gettin replaced, they replaced the belt too cuz it was pretty much worn down and it got rid of it completely. Havent had a problem since, well now its shaking, but thats cuz i need to do an alignment.
Apr 23, 2007 - 4:47 PM |
Enthusiast Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
couldn't it also be that he needs to get his wheels realigned? or would that not cause it to shake like that i really wish i knew more about this kind of stuff
Apr 23, 2007 - 5:47 PM |
yea if hes out of alignment it will make the wheel shake too.
Apr 23, 2007 - 7:36 PM |
Enthusiast Joined Feb 8, '06 From Nova Scotia, Canada Currently Offline Reputation: 1 (100%) |
i too have an annoying shake at moderate to high speeds. funny thing is it's worse on some days than others. if it were balancing it would be there all the time, no? can a bent axle do this? it is just me? more sensitive to it in certain conditions. what about an out of kilter rim? any suggestions ? should i replace the rims or the axles? my tire shop swears they are balanced. and whatever happened to high speed balancing? they just plop the wheel/tire assembly on a really expensive-looking rig and spin it about 50 rpm. the display tells them where to put the weights and voila, 50$ later you are balanced. i miss the days when they asked you to leave the room because they spun the works at breakneck speeds, took out the charts, consulted everyone an staff and THEN YOU WERE BALANCED!! for real real, not for play play.
sorry for the diatribe.. i ment to say yes, check your balance, rims, belts and axles...in that order. peace This post has been edited by axelrduvirage: Apr 23, 2007 - 7:39 PM -------------------- |
Apr 23, 2007 - 8:54 PM |
thanks for all the replies everyone. ive been holding out on new tires, and i rotated the front to back about a month ago. the car is new to me so its been a learning experence.
so... check my power steering pump, re-balance wheels. the car hasnt hit anything, (other than that lazy squirell i clobbered yesterday goin 40) ...like i was saying, the car hasnt hit anything hard to my knowlege. should i check the alignement and axles too? -------------------- |
Apr 23, 2007 - 9:41 PM |
Enthusiast Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
Steering wheel vibration is usually unbalanced tires/wheels.
Easy way to see is rotate wheels front to back. If something changes [even just the speed it vibrates at], it's most likely the wheels/tires. It can be the alignment too. Or a slipped belt in the tire, but that's usually at low speeds. If it's intermittent, it's more likely to be a bad ball joint or suspension component. The machines we have now are MUCH more accurate than the old school way. I know it doesn't look like much, but for that kind of stuff computers are better than humans. -------------------- |
Apr 25, 2007 - 7:20 AM |
Enthusiast Joined Apr 26, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
i have a small amount of vibration in mine, however it cycles. so the vibration will get worse for about 10secs, then get better for 10secs..etc etc
only does it going above 80kmh i know my tires need replacing, just weird that it cycles like that |
Apr 25, 2007 - 4:44 PM |
Enthusiast Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
QUOTE(praetor @ Apr 25, 2007 - 8:20 AM) [snapback]550469[/snapback] i have a small amount of vibration in mine, however it cycles. so the vibration will get worse for about 10secs, then get better for 10secs..etc etc only does it going above 80kmh i know my tires need replacing, just weird that it cycles like that This sounds like a loose rim/improperly torque rims, or you have aftermarket rims and not using hubcentric rings. -------------------- -Rémy 02 SiR, 08 250R |
Apr 25, 2007 - 7:05 PM |
Damn!
I was going to suggest the rear diff as a joke. Then I realized you have a GT4.... This post has been edited by alltracman78: Apr 25, 2007 - 7:05 PM -------------------- |
Apr 26, 2007 - 12:28 PM |
...it also gets worse the faster i go
This post has been edited by boosted95: Apr 26, 2007 - 12:30 PM -------------------- |
Apr 26, 2007 - 3:20 PM |
Enthusiast Joined Dec 28, '04 Currently Offline Reputation: 7 (100%) |
It also could be your brakes, does it pull a little to one side or any excess brake dust on one wheel?
Apr 27, 2007 - 12:13 AM |
Enthusiast Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
bent rim?
-------------------- Is this good enuff 4 ya? :D
Apr 27, 2007 - 12:27 AM |
if it pulls to one side while braking its from a warped rotor
Apr 27, 2007 - 6:00 AM |
If it pulls to one side it's from a caliper sticking or a rotor with a rougher surface than the other side.
Or better tire grip on that side. Or a small chance of several other things. Warped rotors will cause the pedal to pulsate, not make the car pull.... -------------------- |
Lo-Fi Version | Time is now: January 11th, 2025 - 2:44 PM |
