> EGT Probe Elimination, 2nd gen 3sgte
post Apr 24, 2007 - 4:24 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Anyone have any info on removing the EGT probe on a JDM 3S ? Not unscrewing it laugh.gif, eliminating it completely. Or could I just zip tie it somewhere in the engine bay ? New down pipe I'm getting doesnt have a bung for this JDM probe.
Thanks guys
DEF
I will return one day.
Replies (1 - 13)
post Apr 24, 2007 - 5:06 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Just don't use it. I didn't on my RC swap and it didn't throw a code... Actually I'm not even sure if it even made it's way into the ECU... It may have just been for the catalytic convertor dummy light on the JDM combo meter.
Did something happen to your SSAC DP?
This post has been edited by WannabeGT4: Apr 24, 2007 - 7:13 PM
post Apr 24, 2007 - 5:38 PM
QUOTE(WannabeGT4 @ Apr 24, 2007 - 6:06 PM) [snapback]550197[/snapback]
Did something happen to you SSAC DP?
yea, thats what we were talking about last night..i was thinking that it was just for a dash light, but i havent seen one lit up to say for sure.
post Apr 24, 2007 - 6:24 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i never used mine. no check engine lights.
post Apr 24, 2007 - 6:31 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(presure2 @ Apr 24, 2007 - 5:38 PM) [snapback]550211[/snapback]
Thats why when I was doing the wiring conversion on my 3sgte, I couldnt find where the wires for the egt. went to. redface.gif
post Apr 24, 2007 - 7:02 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
You guys pwn the internet.
Justin- I'm picking up the new berk pipe. His new version doesnt support this jdm egt probe. So I wasnt sure what to do about the probe. I'm tired of looking at that ssac pipe. The berk pipe is amazing.
post Apr 24, 2007 - 7:09 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(defgeph @ Apr 24, 2007 - 7:02 PM) [snapback]550249[/snapback]
post Apr 24, 2007 - 7:15 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
So the V3 is finally available? I might think about picking one up then. I haven't had any problems with my SSAC pipe but it's always in the back of my mind.
post Apr 24, 2007 - 7:27 PM
QUOTE(WannabeGT4 @ Apr 24, 2007 - 8:15 PM) [snapback]550261[/snapback]
he's doing a pre-production GB on mr2oc right now for 150 + shipping IIRC.
the normal GB price will be 199, and it will be 249 once the GB's are done.
post Apr 24, 2007 - 7:40 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Manny is correct. Its an awesome deal.
post Apr 24, 2007 - 7:42 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Wow. that's a hell of a deal on the pre-order price. I've gotta go find the post at mr2oc. I wonder if this thing is going to clear the AC compressor and lines with that flex pipe built into it.
post Apr 24, 2007 - 9:31 PM
someone should point this out to berk. im willing to bet he would revise the pipe to include the sensor.
does it still have the 2nd o2 port for a wideband?
post Apr 24, 2007 - 10:21 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(lagos @ Apr 24, 2007 - 10:31 PM) [snapback]550331[/snapback]
I talked to him already. He's not including it.
The wide band bung is an add on feature for 25 bucks. Stock the down pipe comes with the single o2 sensor.
post Apr 25, 2007 - 3:37 AM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(lagos @ Apr 24, 2007 - 7:31 PM) [snapback]550331[/snapback]
The JDM EGT sensor is not so much a sensor as a switch. At a certain temp, it closes the circuit. Unplugging it completely causes no problems. The sensor is for the cat, not the motor - and when the cat is gone, there is no need for the sensor.
Anybody serious about performance will have an aftermarket EGT gauge installed to see real temps anyway...
-Charlie
This post has been edited by phattyduck: Apr 25, 2007 - 3:37 AM
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: December 1st, 2024 - 1:18 PM
