FS: Cheap set of GT headers on eBay |
May 11, 2007 - 10:38 AM |
Enthusiast Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
http://cgi.ebay.com/ebaymotors/STAINLESS-H...116345308QQrdZ1
if that link doesnt work, the auction number is 140116345308 Someone pick this up. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
I'm not really an asshole, but I play one on the internet. **** Photobucket |
May 11, 2007 - 10:57 AM |
Enthusiast Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) |
Hot
May 11, 2007 - 11:27 AM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
That one is a direct bolt up to the stock setup so would be pretty good for someone. It's a 4-1 so could be a little better but I like mine and its similar. Check the placement of the o2 sensors with no cat inbetween. Probably will cause a cel in OBD-II cars [IDK about OBD-I cars]. Also def will cause you to fail smog. 304 SS is ok in the manufacturing world [could be much better] - I have no idea if that's good as far as exhausts go.
Should feel a noticeable difference in top end. Just thought people should be informed of the facts before they buy. This post has been edited by Negative: May 11, 2007 - 1:48 PM -------------------- |
May 11, 2007 - 2:21 PM |
Any idea if this header would require the cat to be removed or will it bolt up the existing one, just replacing the stock manifold? I'd pretty well only buy this if that were the case. My exhaust is in great shape and I'm not up for redoing it for the sake of adding this header.
This post has been edited by Sinyk: May 11, 2007 - 2:23 PM -------------------- |
May 11, 2007 - 2:29 PM |
QUOTE Any idea if this header would require the cat to be removed or will it bolt up the existing one, just replacing the stock manifold? I'd pretty well only buy this if that were the case. My exhaust is in great shape and I'm not up for redoing it for the sake of adding this header. It would replace your 1st cat and exhaust manifold (obviously). -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
May 17, 2007 - 3:47 PM |
Enthusiast Joined Jul 12, '06 Currently Offline Reputation: 2 (100%) |
This is where I got my 4-1 header. The truth is I never got to install mine because I had issues with the alternator, the header bolts on straight but it makes contact to the alternator so I am selling mine. He said it can be fixed by using header wrap. The ebay seller said he had no problems with the other buyers. If anyone here in 6gc is interested PM me.
Here is the pic. Brand new never used: |
May 17, 2007 - 3:52 PM |
mmm... not sure I'd want it resting against the alternator. Couldn't that cause problems? I mean, installing it, all you do is loosen the adjusting bolt and tilt the alternator back to get the header on right?
May 17, 2007 - 4:00 PM |
QUOTE(Sinyk @ May 17, 2007 - 2:52 PM) [snapback]558960[/snapback] mmm... not sure I'd want it resting against the alternator. Couldn't that cause problems? I mean, installing it, all you do is loosen the adjusting bolt and tilt the alternator back to get the header on right? I might be installing it wrong. I did get the header in position by loosening a bolt on the alternator, set aside the belt to lift it up, put the header in place, then when I am about to put everything back, it seems that there is just no space left to squeeze everything up. Could it be possible that my alternator set up is just too close to the header? Are all engine components spaced the same for Toyota cars? I might be missing something... This post has been edited by kcizzle: May 17, 2007 - 4:02 PM |
May 19, 2007 - 1:00 AM |
Enthusiast Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) |
The only thing is with a OBDII celi's that header would jump the code. Because it only has one o2 sensor on the header. I wanna find one that has both sensors on the header so i don't jump a code.
May 20, 2007 - 4:32 PM |
Header sold to Quintin GT.
Lo-Fi Version | Time is now: January 9th, 2025 - 9:40 PM |
