![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) ![]() |
So, the other day I went out and bought a voltage tester so I could I find a wire to wire power to my gauges. well, while I was using a razor blade to cut into the wires to test them, I accidentally cut two wires at once and it smoked when I did so. thing is, after that, my alarm no longer worked. kinda an annoyance, but not really the biggest deal in the world. but then when I went to start the car this morning to go to work, it didn't start. turn the key and, nothing! no click, no turning over, just nothing. so I pulled practically half the dash apart to trace the wires. well, while it was pulled apart, I was able to start the car! well, I did what I orginally planned to do in the first place and got my gauge (soon to be gauges) wired up. put everything back together, and went to start the car and guess what? nothing happened! I checked ALL my fuses twice! none of them are blown out. so I don't know what to do. I know the wires I hacked into, one was red, the other was blue with a black stripe. I traced the red one to the switch that arms/disarms the alarm. and the other wire to one of the white connectors down there. I don't know where the other ends of the wires end up though. so can anyone help me in any way? I'd be satisfied with no alarm as long as I can get my car to start!
Btw, I'm pretty sure it's the stock alarm, but I found the sensor for it, and both that and the keyless entry remote say "clifford" on them, so maybe it's an aftermarket clifford alarm? or is the stock alarm clifford? -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Enthusiast ![]() Joined Dec 24, '06 From Okinawa Japan Currently Offline Reputation: 0 (0%) ![]() |
Does your car have a automatic start thing hooked up to your alarm system?
If so, you could of blown your alarm system box and some alarms have a circuit going through that box to start the car. |
it doesn't have remote start, but I'm pretty sure it has a way to disable the starter if the alarm is disconnected, as a security feature.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
like i said in your other post.
did you check your main fuse? the big ones under the hood? |
QUOTE(Hanyo @ May 22, 2007 - 11:20 PM) [snapback]560762[/snapback] like i said in your other post. did you check your main fuse? the big ones under the hood? no I didn't. but after I read that in the other post I did go out and check and they are all fine. However! I disconnected the negative battery cable for a minute, put it back on, and when I did so, I heard the door lock. I went around, unlocked it, got in the car, and it started! weird. still, it could still not start when I go to try tomorrow morning. I'd like to get the problem fixed! -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
so the car works now after having disconnected the battery and reconnecting it. however, the alarm still doesn't...
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) ![]() |
I'd probably disconnect the alarm completely. I already did this to my car. Just unplug the unit and see if it will start. If it does, either spend the time to find the problem or take the unit out completely. IMO
Lo-Fi Version | Time is now: February 20th, 2025 - 3:52 AM |
