> whats the best way to run power to my amp in my trunk?, its a 95 ST...
post May 31, 2007 - 10:19 PM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
i got an insane deal on a ported box from a friend, its a lame setup but i couldnt pass it up for the price.
here's the list
jensen 10'' sub x2
jensen 200w amp
large sealed and ported jensen box
total cost to me $45
i went to the car audio guy and bought the "kicker" 4awg 1000w maximum cables, it was a kit so i have all i need, right???
poopra sellout... 88targa, 50trim ct, 383lsd, and shreadin tires like its my job!!!
QUOTE (RUNNIN-LOW @ Feb 17, 2009 - 1:53 PM) *
buying a rusty car is like dating a girl with a bush! if u like it like that go for it.. :D if u can repair and make it look better then its all the better for u!...
Replies (1 - 5)
post Jun 1, 2007 - 1:02 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yes, it should include all you need
which is:
+12v wire(long)
ground wire (short)
REM wire(that you put on the ACC wire that goes to your radio)
RCA patch cables.
some pointers...
1. run the RCA lines on the opposite side of the vehicle from the power wire, otherwise you may get alternator whine.
2. find a good, solid ground, like a bolt that goes into the chassis, remove it, and w/ a wire brush, clean it senseless, if not, you may create a "ground loop" which again, will cause alternator whine.
3. Mount everything very good!!! i cannot tell you the importance of that.. when i 'drive spirited' my sub flys around my hatch and rips the wires out from my amp. not good.
post Jun 1, 2007 - 6:53 AM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
QUOTE(stephen_lee @ Jun 1, 2007 - 6:02 AM) [snapback]563691[/snapback]
which is:
+12v wire(long)
ground wire (short)
RCA patch cables.
some pointers...
thanks, yes its all there but could i ask how you hook your +12v wire to your battery. and from there how do you run it to the trunk? is there a hole in the firewall? or do i send it through the fender?
post Jun 1, 2007 - 6:59 AM
cnelson
Joined Dec 11, '06
From New Jersey
search.. "how to properly run power to your amp" i think that was the topic name, somone did a very good write up how to do it, and do it the right way.
"Drive Well...
...Drift Better"
post Jun 1, 2007 - 7:33 AM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
thank you
post Jun 1, 2007 - 7:49 AM
bman
Joined May 14, '07
From Long Island
power on the driver side, audio on the passenger - the celica is a very forgiving car to work in. i made my hole (1/2) neat the fuel linkgage
94 Celica ST - CAI, CarPuter, many interior mods!
Lo-Fi Version Time is now: February 13th, 2025 - 4:13 PM
