> Powerloss....
post Jun 14, 2007 - 7:58 PM
Remy
Joined Jan 25, '06
From MN
Hey guys I've been having a lot of problems with my celi lately....sagging lights, nails in tires, keyed, smoking etc... now its getting to me my engine have been running worse by the min...it seems like its losing alot of power when I floor it, it doesn't go anywhere dunno whats wrong maybe its time to retire this motor I know 5s aren't strong but mines usually pick up better then this....I was thinking maybe bad fuel pump or bad injectors. When I slam on the gas (just testing the car) it seems to slowly pick up my 0-60 is prob in the 30s... frown.gif any advice on this ?? I was gonna try some fuel injector cleaner see if that helps anything else you guys think I should try ??
Replies (1 - 15)
post Jun 14, 2007 - 8:21 PM
manual or automatic?
post Jun 14, 2007 - 9:07 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(Bitter @ Jun 14, 2007 - 8:21 PM) [snapback]568624[/snapback]
Edit: Could the timing belt affect this ?? When I bought the car I did a fresh tune-up but didn't get a chance to change the T-belt and my timing is not advanced.
Edit 2: When I press on gas it feels like somethings clogged and the speed slowly goes up....?
This post has been edited by Remy: Jun 14, 2007 - 9:10 PM
post Jun 14, 2007 - 11:17 PM
cheeco
Joined Jun 15, '06
From NJ
very poor acceleration could be caused by a jumped tooth on the t-belt. you would notice very poor accel on the low end that seemed to be better when the revs got up higher. other things that could cause this, off the top of my head, kinked exhaust or badly clogged intake.
post Jun 14, 2007 - 11:30 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
When was the last time you changed your fuel filter? If you can't remember when, or its been more than 15k miles, its time to change it. the part would only cost about 20 bucks, and you can do it yourself if thats the problem.
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Jun 15, 2007 - 12:09 AM
Remy
Joined Jan 25, '06
From MN
QUOTE(cheeco @ Jun 14, 2007 - 11:17 PM) [snapback]568680[/snapback]
I checked the t-belt it's still good exhaust and intake is fine.
QUOTE(CaliJeff @ Jun 14, 2007 - 11:30 PM) [snapback]568688[/snapback]
Fuel filter was changed 2 months ago I'm sure its still good.
Edit: Well I just put in some fuel system cleaner I'm gonna see if that does the trick and let it sit overnight.
This post has been edited by Remy: Jun 15, 2007 - 12:12 AM
post Jun 15, 2007 - 10:50 AM
you sure its not a slipping clutch?
post Jun 15, 2007 - 11:10 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
QUOTE(Bitter @ Jun 15, 2007 - 11:50 AM) [snapback]568813[/snapback]
X2
post Jun 15, 2007 - 3:31 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i think he was describing the revvs picking up slow also.
post Jun 15, 2007 - 4:26 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Run some seafoam through your throttle body. While it may not fix the problem it sure is a lot of fun. It'll clean your engine nicely.
post Jun 15, 2007 - 6:22 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(Bitter @ Jun 15, 2007 - 10:50 AM) [snapback]568813[/snapback]
Nope my clutch is still good.
QUOTE(stephen_lee @ Jun 15, 2007 - 3:31 PM) [snapback]568892[/snapback]
Yep
QUOTE(GTS13 @ Jun 15, 2007 - 4:26 PM) [snapback]568898[/snapback]
I hear bad stuff about seafoam but never actually tried it maybe I will this weekend
Well I put the FIC in it helped a lot but it still seems under-powered...Thanks for all the help though guys, thumbsup.gif but I think the engine is just getting old...170k on the chassis 120k on the motor.
post Jun 15, 2007 - 6:41 PM
6gcSTVT
Joined May 3, '06
From New Hampshire
At 120k your motor shouldn't be tired, there has to be something else wrong
Darin H.
post Jun 15, 2007 - 6:44 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(6gcSTVT @ Jun 15, 2007 - 6:41 PM) [snapback]568935[/snapback]
I agree but when I bought this car it was in pretty bad shape....lets just say it was a project car the only thing good about it was the body no rust..... frown.gif
post Jun 17, 2007 - 5:37 PM
trdproven
Joined Aug 2, '05
From Guam
Only things on my mind like mentioned are:
Fuel Pump
Slipping Clutch
Tune-Up Needed
Clogged Air Filter
Leaking Hose
My 5sfe Camry is also slow accelerating from 0mph. I cannot figure it out. What makes my problem harder is that it is random.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jun 17, 2007 - 10:57 PM
Remy
Joined Jan 25, '06
From MN
Now my car is running good again weird the only thing I tried was putting in fuel cleaner I guess my fuel system just needed to be clean thanks alot guys you guys ROCK !! biggrin.gif thumbsup.gif
post Jun 18, 2007 - 7:17 PM
trdproven
Joined Aug 2, '05
From Guam
Did you use a fuel injector cleaner or gas treatment?
Send me a PM if you have the chance.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: February 22nd, 2025 - 9:48 AM
