A lot of squeeking coming from rear? |
Jun 17, 2007 - 2:03 PM |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
I'm not very good mechanically, so I think it's a wheel bearing or brakes. It only happens when i'm rolling though. It's decently loud too.
Jun 17, 2007 - 4:51 PM |
Enthusiast Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) |
QUOTE(Akimbo @ Jun 17, 2007 - 12:03 PM) [snapback]569307[/snapback] I'm not very good mechanically, so I think it's a wheel bearing or brakes. It only happens when i'm rolling though. It's decently loud too. bearing is very possible -------------------- |
Jun 17, 2007 - 9:01 PM |
my rear end used to squeak and it turned out to be the shocks.
Jun 17, 2007 - 10:07 PM |
better not be, those are brand new. im thinking pads now.
Jun 17, 2007 - 10:59 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Squeaking sound ?? Yeah its the pads then.
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Jun 17, 2007 - 11:03 PM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
is it when your driving you hear it all the time? or is it you only hear it when you hit the brakes? or when you hit a bump or when?? I have a squeak coming from my rear end too, but mine only happens when i hit a bump and its because i got a bad strut rod bushing.
Jun 17, 2007 - 11:07 PM |
Enthusiast Joined Jul 12, '06 Currently Offline Reputation: 2 (100%) |
Try this link:
http://www.6gc.net/forums/index.php?showtopic=45402 |
Jun 19, 2007 - 7:28 AM |
Enthusiast Joined Feb 26, '06 From Bowling Green, OH Currently Offline Reputation: 1 (100%) |
I have had this problem too. Every now and then, at low speeds, I hear this squeaking when I leave on the gas and coast. I suspect the wheel bearing as well, but time will tell when I do coils and struts. I'll check it sometime if you'd like. I don't claim to know all, but I know enough to diagnose right more often than not.
Jun 19, 2007 - 10:47 AM |
Enthusiast Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Ive got a squealing type of noise that seems to amplify when I am on the gas, and less while coasting. Its like it gets louder as the RPM's increase, but it doesn't make much noise while going over bumps. I suspect its a wheel bearing more money that isn't going to mods.
This post has been edited by 95CelicaST: Jun 19, 2007 - 10:48 AM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
I'm not really an asshole, but I play one on the internet. **** Photobucket |
Jun 19, 2007 - 12:12 PM |
I for once dont believe thats the bearing, perhaps an axle
Jun 19, 2007 - 12:26 PM |
QUOTE(LewFX @ Jun 19, 2007 - 10:12 AM) [snapback]570033[/snapback] I for once dont believe thats the bearing, perhaps an axle I will add that it is coming from the rear passenger side. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jun 19, 2007 - 1:42 PM |
ahhh, that would help, if you need a rear bearing without abs, let me know i have one
Jun 19, 2007 - 2:33 PM |
QUOTE(LewFX @ Jun 19, 2007 - 11:42 AM) [snapback]570054[/snapback] ahhh, that would help, if you need a rear bearing without abs, let me know i have one depending. I'm going to have my mech. look at it and if he says its the wheel bearing then I will come knocking. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jun 19, 2007 - 3:33 PM |
Enthusiast Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
other from what u guys said...wanna check teh dust shields to see if its bumping on the rotor....
Jun 20, 2007 - 6:26 PM |
Enthusiast Joined May 20, '07 From Massachusetts Currently Offline Reputation: 0 (0%) |
should also check the rear tierod and control arm bushings, spray some silicone onto the bushings (one at a time), and take it for a ride, if noise goes away, bingo!
should also check the rear tierod and control arm bushings, spray some silicone onto the bushings (one at a time), and take it for a ride, if noise goes away, bingo! |
Lo-Fi Version | Time is now: November 25th, 2024 - 11:21 PM |
