> Need help on installing the stock headunit, what did i miss??
post Jun 22, 2007 - 8:19 PM
zombie
Joined Feb 1, '06
From Los Angeles
when i bought my car...
it came with this headunit
and here is the wire :
i took all of it off today and left with this wire:
i am trying to put this factory headunit into my car and finds out that the hole for me to connect is not the same as the old one
can anyone point me out what do i need to plug those wires in?
did i miss anything?
Replies (1 - 19)
post Jun 22, 2007 - 9:42 PM
azian_advanced
Joined Apr 18, '05
From Calgary
leave the blue connectors plugged in, they are what links the speakers to the amp.
you'll also need the 8 speaker stereo harness that goes from the amp to your new stereo.
Part Number: 86203-20200 $24
post Jun 22, 2007 - 10:37 PM
zombie
Joined Feb 1, '06
From Los Angeles
QUOTE(azian_advanced @ Jun 22, 2007 - 7:42 PM) [snapback]571441[/snapback]
i dun have any amp...
and i am driving an st which have 4 speakers only i think...
post Jun 22, 2007 - 10:43 PM
zombie
Joined Feb 1, '06
From Los Angeles
[quote name='azian_advanced' date='Jun 22, 2007 - 7:42 PM' post='571441']
by the way, "leave the blue connectors plugged in, they are what links the speakers to the amp."
but the one in ur photo isn't plugged into anything?
and i dun have that box as well...
post Jun 22, 2007 - 11:00 PM
I3arruka
Joined Feb 20, '07
From The Chi, Illinois
If i'm not wrong, u should be able to use that stereo w/an st. The back of the unit has a slot for both the st and gt.
PS how did u get all that sh*t out?! it is so cramped for space in there
"Pain is weakness leaving the body of the strong"
post Jun 22, 2007 - 11:06 PM
zombie
Joined Feb 1, '06
From Los Angeles
QUOTE(I3arruka @ Jun 22, 2007 - 9:00 PM) [snapback]571467[/snapback]
I juz follow the guidelines here..and download that pdf
http://www.6gc.net/forums/index.php?showtopic=22434
u mean i dun need an amp
and i can plug it right in?
cause the blue connectors in my car doesn't fit that though
post Jun 22, 2007 - 11:27 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i see, so you have the standard toyota setup (4 speaker setup) that requires those two blue connectors to hook up to most standard toyota stereos (like this for example). although, the toyota stereo that you have requires the 6 or 8 speaker harness plus the amp.
post Jun 22, 2007 - 11:38 PM
zombie
Joined Feb 1, '06
From Los Angeles
QUOTE(azian_advanced @ Jun 22, 2007 - 9:27 PM) [snapback]571475[/snapback]
so what can i do...?
any help?
post Jun 22, 2007 - 11:42 PM
azian_advanced
Joined Apr 18, '05
From Calgary
the best thing to do is find a different compatible stereo and sell the one you have.
post Jun 23, 2007 - 12:19 AM
zombie
Joined Feb 1, '06
From Los Angeles
QUOTE(azian_advanced @ Jun 22, 2007 - 9:42 PM) [snapback]571481[/snapback]
o my god............
post Jun 23, 2007 - 12:23 AM
zombie
Joined Feb 1, '06
From Los Angeles
QUOTE(zombie @ Jun 22, 2007 - 10:19 PM) [snapback]571490[/snapback]
can i buy anything to add on the the head unit and make it adaptable???
post Jun 23, 2007 - 11:39 AM
azian_advanced
Joined Apr 18, '05
From Calgary
probably not. you see, the stereo you have now doesn't have a built-in amplifier like most toyota stereos. it requires a factory toyota amplifier to hook up to it and then wired to your speakers.
if you really want to use that stereo, then you'll need the 6 or 8 speaker harness and amplifier.
post Jun 24, 2007 - 1:35 AM
zombie
Joined Feb 1, '06
From Los Angeles
QUOTE(azian_advanced @ Jun 23, 2007 - 9:39 AM) [snapback]571570[/snapback]
how much is an amp around
and do i need to add 2 speakers and make it 6 instead of 4?
post Jun 24, 2007 - 11:26 PM
zombie
Joined Feb 1, '06
From Los Angeles
will this amp work for my system?? any help?
This post has been edited by zombie: Jun 24, 2007 - 11:26 PM
post Jun 25, 2007 - 1:00 AM
6strngs
Joined May 12, '06
From Wilmington, NC
I don't think that's the stock head unit. at least, it doesn't look like the one I had.
post Jun 25, 2007 - 1:01 AM
zombie
Joined Feb 1, '06
From Los Angeles
QUOTE(6strngs @ Jun 24, 2007 - 11:00 PM) [snapback]571782[/snapback]
which pic are u referring to?
post Jun 25, 2007 - 1:06 AM
zombie
Joined Feb 1, '06
From Los Angeles
QUOTE(zombie @ Jun 24, 2007 - 11:01 PM) [snapback]571783[/snapback]
the guy who sold me this told me that it's off from a gt convert
This post has been edited by zombie: Jun 25, 2007 - 1:07 AM
post Jun 25, 2007 - 1:31 AM
6strngs
Joined May 12, '06
From Wilmington, NC
mine looks like this:
it's in two pieces, one for CD, and one for cassette/radio. one black wire in the back connects the two. it might be different for a convertible, but this came stock on my GT hatch w/ 6 speaker set-up. here's some pics I took of the stickers on them so you could see the part numbers:
This post has been edited by 6strngs: Jun 25, 2007 - 1:34 AM
post Jun 25, 2007 - 2:31 AM
zombie
Joined Feb 1, '06
From Los Angeles
mines part number is 86120-14880
so i guess they are from different models...
post Jun 25, 2007 - 5:52 PM
azian_advanced
Joined Apr 18, '05
From Calgary
there are different stereos for the celica. mine looks like this. but the model of the stereo doesn't really matter, just that for the celica it's either the non-amplified stereo (6 or 8 speaker setup) or amplified stereo (4 speaker setup).
and if it really did come off a celica convertible, then it's probably one from either the 98 or 99 ones.
Lo-Fi Version Time is now: November 27th, 2024 - 10:45 AM
