> I'm stumped, any ideas?
post Jun 27, 2007 - 11:56 AM
calgarygts
Joined May 13, '07
From calgary
I've got a squeaking/grinding noise coming from the front passenger side wheel. I got the wheel off, took the brakes apart and everything looks good - pads look almost brand new. When I take the pads off the squeak goes away, but when I'm driving the squeak is dependent on wheel speed and doesn't change when I hit the brakes.
It's more of a squeak than a grinding noise, definitely not the wheel bearing or cv joint.
Any ideas?
Replies (1 - 5)
post Jun 27, 2007 - 12:46 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
you sure its not a bearing because i was in a similar situation...i bought new brake pads and rotors and still squeels...changed out the bearing and now no noises what so ever
post Jun 27, 2007 - 2:45 PM
6gcSTVT
Joined May 3, '06
From New Hampshire
I had brake pads that took a couple thousand miles just to stop making a small noise like its rubbing...I prob should have readjusted them but the brake sound went away eventually.
Darin H.
post Jun 27, 2007 - 2:58 PM
LewFX
Joined Jan 28, '05
i went over a year of this problem, 6 alignments in one year, 2 sets of rotors and pads, wheel balance, rotations. conclusion=bad bearing...sucky goodyear didnt do the job right, bearing was seized on hub.
post Jun 28, 2007 - 4:36 PM
nyawton
Joined Jun 1, '07
From UK
Mine was same,, It Was the anti Squeel Plates that fit to back of pads missing. I just used some copper slip on the back of the pads & Noise has gone smile.gif
post Jul 28, 2007 - 12:19 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Have you tried some hard braking? I've notice sometimes with new pads you have to give them a couple of hard brakes to get rid of the coating on them... that might be it...? kindasad.gif
I notice you're in Calgary - with a GTS... would you mind letting me know who you're getting your parts through?? I'm new to town and I dread taking my GTS to the "stealer"-ship.
Lo-Fi Version Time is now: February 22nd, 2025 - 1:20 AM
