> Door adjustment
post Jul 2, 2007 - 4:20 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
One of my doors are not lined up(installed) properly by the last owner causing the top of the glass to hit the top rubber trim and not closing properly.
It is slightly tilted upwards away from the hinges instead of parallel to the body/ground. How do I go about adjusting it back?
Pic shows what I am talking about(exaggerated view but u get the idea)
This post has been edited by soven: Jul 2, 2007 - 4:28 AM
Replies (1 - 11)
post Jul 2, 2007 - 7:26 AM
nyawton
Joined Jun 1, '07
From UK
Hi there, I havent had time to look at the hindges on my car yet, But as far as im aware , cars dont genrally have adjustment as such?
If not would it be possible to pack the top hindge out to align the door better?
Also u have any idea what make of spoiler that is? Looks nice!
post Jul 2, 2007 - 9:40 AM
measure the seams of the doors if they are ok all the way, maybe only the window needs adjusting..
post Jul 2, 2007 - 12:11 PM
Valo666
Joined May 15, '05
From Toronto
only thing that you might b able to do, loosen off the 2 screws that hold the door striker onto the frame, tap it down a bit. that should settle your door down a little bit.
post Jul 2, 2007 - 5:12 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(nyawton @ Jul 2, 2007 - 6:26 AM) [snapback]574279[/snapback]
that spoiler came stock on the ssIII. it is just the stock 2post spoiler with risers if you want to put it on your car. just contact doggy or whoever is selling them.
sorry to hear about your door bro. i hate it when little things like that happen. i love your car though. i wish i could get a hold of a ssIII.
gl with getting it fixed.
post Jul 3, 2007 - 2:50 AM
soven
Joined Mar 14, '05
Thanks for the replies, If I look along the body line where the door meets quarterpanels.. I can see that the door is very slightly higher which seems to be the culprit. Will take a good look at the glass but I am pretty sure it is not the glass that is causing the problem.
post Jul 3, 2007 - 8:16 AM
nyawton
Joined Jun 1, '07
From UK
Kewl smile.gif Cheers think i will start saving my pennys , Good luck wi the door!
post Jul 3, 2007 - 8:34 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
adjust the hinges inside the fender
BOOST GETS YOU LAID!!!!
post Jul 3, 2007 - 12:40 PM
azian_advanced
Joined Apr 18, '05
From Calgary
maybe this'll help: How to adjust your door
if you follow the how-to, you can adjust the metal plate inside the door striker up a notch.
post Jul 3, 2007 - 2:45 PM
soven
Joined Mar 14, '05
Just what I needed. Thanks guys. Will get onto it soon and report back
post Jul 3, 2007 - 8:06 PM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
be careful when adjusting the door
This post has been edited by b1gr3d: Jul 3, 2007 - 8:07 PM
Coming in 2010
post Jul 8, 2007 - 5:25 PM
soven
Joined Mar 14, '05
Would just like to update that I have solved the issue. Mucked about with the door striker for close to an hour before i decided it was going nowhere.
Removed front bumper. removed fender. Got to the top two hinge bolts, made it loose, shut door and then tightened them back up. All good after that.
Lo-Fi Version Time is now: February 21st, 2025 - 9:26 AM
