> 3 post to 2 post hatch, Not recommended but here is how to line up to drill.
post Jul 5, 2007 - 7:27 PM
97lestyousay
Joined Jul 7, '03
FIND A 94-95 HATCH IF YOU CAN!!!!
You will have holes to fill after completing this!!!
WARNING: If you are not comfortable doing this yourself get help.
I would highly advise using a 94-95 hatch if there is anyway to do so.
I take no reponsability for your misinterpatation of my lingo, nor am I
responsable in anyway for you choosing to do this to your hatch. I am also
not the greatest speller in the world, so you have been warned.
STEP 1: I bought 2 metric set screws, (head less)(they use an allen wrench inside the screw itself) the same size as stock hatch bolts. (available at ace hardware)
STEP 2: Screw the setscrew into front 2 spoiler holes so they barely stick out beyond flush.(be careful adjusting spoiler on car as the will scratch the
hell out of your paint) If you are doing it alone cover the hole area to be drilled
with a rag on both sides.
STEP 3: Line up holes in hatch with 2 post holes (the .390" ones in back that actually line up not the slots.)
STEP 4: Start screws in back holes till a little less than finger tight and try to center the bolt hole in hatch with the tapped hole in spoiler as best you can.
STEP 5: Remove rags from under set screws in front part of spoiler.
STEP 6:Lightly snug rear bolts(a little more than finger tight) and re center
as close as possable.
STEP7: Tap down on front part of spoiler lightly (with hand, NOT hammer)
this will create a witness mark(sratch in paint) from the set screws into the hatch itself.
STEP8: Carefully remove spoiler.
STEP9: Remove setscrews from spoiler. ( look at hatch to make sure it is clearly marked, if not, skip 9 go back to step 3 and start over, tapping a little harder)
Step 10: MOVE WIREING HARNESS IN HATCH OUT OF WAY!!!!
Use small drill to start with. ( I used 1/8 in and worked up from there)
I drilled the holes and double checked everything as I went. Drill through
both walls of hatch(must be part open or you will drill into car)
STEP 11: From inside of hatch, drill with hole saw up to 3/4" (INSIDE WALL ONLY)
Using smaller hole as pilot.
This post has been edited by 97lestyousay: Jul 5, 2007 - 11:17 PM
JDM guy made me do it.
Replies (1 - 6)
post Jul 6, 2007 - 6:21 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
from this post http://www.6gc.net/forums/index.php?showto...p;p=489063&
How I removed my spoiler and covered the holes and where you have to drill to convert to a 2 post.
I just used a clear vinyl sticker to cover the holes but they've held up very well for a good 9+ months now and I can take them off if I need/want to.
QUOTE(hurley97 @ Oct 8, 2006 - 1:36 PM) [snapback]489063[/snapback]
There are two screws for each outer post and one for the middle post. The third hole on the outers is where the plasic piece snaps into. One of the holes that are already there should match up with the 2-post. The area circled is where you have to drill the other hole, you'll notice how it flattens/flares out a little.
there was adhesive on mine that took some time to get off (using Goo Gone)
I didn't think I would but I kind of like the spoiler-less look so until I have the time/money to put the 2 post on it will stay that way. I bought an etched vinyl/sticker (of a chevy logo wink.gif ) from Autozone and cut out the clear parts to cover the holes, I figured it would be the easiest to get off later and stay better than some kind of tape because it's made to go on cars. I put some electrical tape on the underside as well, just for the hell of it.
I <3 Dustin---07/16/06
post Jul 12, 2007 - 9:32 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
Good stuff guys. I would recommend buying a 94-95 hatch as well if you can find one... I got a really good deal on a 94 hatch for my 98 for 125 bucks with the glass and everything. It was already red too which was nice. smile.gif
This post has been edited by RbrtNdrws: Jul 12, 2007 - 9:33 PM
post Oct 5, 2008 - 9:57 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Gonna make a go at taking my 3 post off today. I found some nylon plugs at Home Depot yesterday, all I have to do is measure up the size of the holes and hopefully that'll be that.
post Oct 3, 2009 - 2:12 AM
TiGZ461
Joined Aug 6, '09
From Bergen County,NJ
Took me a while to find this so might as well bump it for those who might wanna do this mod.
1996 Toyota Celica ST 25th Anni. Edition #461
post Dec 3, 2009 - 8:11 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
This is a good writeup,
However, I am standing here scratching my head as my 1998 SS-III spoiler is sitting on the back of my 1996 GT-Four, the back holes do not line up!!!!!!!!!! frown.gif
It's about 5mm off on either side, if you line up 1 hole the other side is 10mm off frown.gif
EDIT: Nevermind!! It's the middle holes that line up to the back of the 2 post
This post has been edited by delusionz: Dec 3, 2009 - 11:21 PM
Mike W
269awhp / 273ft-lbs
post Apr 6, 2013 - 3:13 AM
Lexa666
Joined Mar 15, '10
From Russia
This post has been edited by Lexa666: Apr 6, 2013 - 3:14 AM
Lo-Fi Version Time is now: February 20th, 2025 - 12:36 PM
