![]() Enthusiast ![]() Joined Dec 22, '05 From Turlock, CA Currently Offline Reputation: 0 (0%) ![]() |
I RECENTLY JUST INTALLED SOME NEW KYB STRUTS, STRUT MOUNTS, AND BOOT ON THE FRONT OF MY COROLLA, yEAH i KNOW THIS IS NOT A COROLLA FORUM. ANYWAYS THE CAR IS LOWERED ON 17S AND I'M USING H&R SPRINGS ALL AROUND.
WHEN GOING OVER SMALL BUMPS THERE IS A SIGNIFICAT AMOUNT OF NOISE COMING FROM THE FRONT END SUSPENSION! I DON'T KNOW WHAT COULD BE CAUSING THIS NOISE? ANY INPUT WOULD BE HELPFUL, THANKS. ![]() ![]() ![]() -------------------- www.cardomain.com/id/snakesolid
![]() Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) ![]() |
Both sides? what kind of sound? squeak or clunk. Made sure you tightened everything properly. Check that the springs are captive.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
i noticed you dont have the rubber piece that goes on the strut that holds the spring.
The noise is more like a thud and its comming from both wheels on both sides at about the same intensity over bumps.
I forgot to mention like "LewFX said" I did not use the lower rubber insulator at the bottom of the springs( look at the pic) I don't know if this makes a difference, anyone know? -------------------- www.cardomain.com/id/snakesolid
QUOTE(soven @ Jul 15, 2007 - 1:58 AM) [snapback]578680[/snapback] Both sides? what kind of sound? squeak or clunk. Made sure you tightened everything properly. Check that the springs are captive. by captive you mean there they are secure right, they are H&R springs so they did not have to be compresed to install the strut mount, I only presed the mount onto the springs compresing them a little and then thightened the nut on the center of the strut mount. -------------------- www.cardomain.com/id/snakesolid
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
it probably comes off the seat as the spring compresses. use that rubber piece.
Most likekly problem causing noise?
Missing lower insulator on stut? SWAY BAR END LINKS? SWAY BAR BuSHINGS? Wheel Bearing? -------------------- www.cardomain.com/id/snakesolid
I think I found the problem!!!
The nut on top of the strut is not thightened all the way. I removed the wheel while holding the buttom of the rotor I presed up and down simulating movement of the suspension and it makes noise, looks like the shaft is moving up and down and the nut because its not tightened all the way allows for movement so the nut is bouncing hitting the mount on the bottom making noise. How do i tighten the nut on the top of the strut shaft withought the shaft moving?(KYB STRUTS) -------------------- www.cardomain.com/id/snakesolid
Get to a shop that has a rattle gun.
![]() Make sure everything is installed correctly first though. There is an arrow on the strut that tells you how to mount it to the car. This post has been edited by soven: Jul 16, 2007 - 2:22 AM |
Lo-Fi Version | Time is now: February 25th, 2025 - 8:14 AM |
