> Tein S-Tech Lower Springs
post Jul 18, 2007 - 6:23 PM
twitchh17
Joined May 19, '06
From North NJ
hey hows it going guys? i just ordered Tein S-Tech springs and was wondering if I should change my shocks? my cars at 179,xxx miles right now and it's on the stock springs my 95 celica gt came with. i heard that if we use KYB GR-2 shocks on our cars the front shocks wont fit. why is that? and what part will I need to make it fit? where can I get that part/parts to make it fit? how much will it cost for the parts? thanks to whoever replies in advance
Replies (1 - 19)
post Jul 18, 2007 - 7:19 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
you probably should get new ones, if you dont do alot of driving and are on a tight budget you can get by without replacing them, its a good idea to replace them all at one, as far as pricing, i havent done much looking online, there a performace shop around me that is giving me some hook ups and a fabricator whos helpin make some new arms etc..
from what ive seen 180 for the springs n about 210 for the shocks seems to be the best - legit - deal
post Jul 18, 2007 - 7:55 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
usually when you buy all 4, they send 2 front inserts
post Jul 18, 2007 - 8:17 PM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(LewFX @ Jul 18, 2007 - 7:55 PM) [snapback]580000[/snapback]
yeah thats what i heard but i also saw a post on here. a guy on this forum bought the kyb gr-2's from eBay. same part number. he even confirmed it with KYB. its something like if you have the GT Sport Suspension that it wont fit. why is that? and how do i know if i have the GT Sport Suspension? I have a 1995 Celica GT. and IF i do have the gt sport suspension, can i do anything to make the kyb gr-2's fit? or should i just get OEM ones from toyota?
post Jul 18, 2007 - 9:28 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
someone should make a how-to for replacing the front strut cartridges.
post Jul 18, 2007 - 9:34 PM
LewFX
Joined Jan 28, '05
you can use the sealed versions:
part #334378 and 334379
post Jul 18, 2007 - 11:45 PM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(LewFX @ Jul 18, 2007 - 9:34 PM) [snapback]580030[/snapback]
when i looked those up on 1sttoyotaparts.com no results came up. what do i ask for from the local toyota dealer? and how do i know if i have the gt sport suspension?
post Jul 19, 2007 - 12:26 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(twitchh17 @ Jul 18, 2007 - 11:45 PM) [snapback]580085[/snapback]
I think those are part numbers for KYB sealed front shocks, not Toyota parts.
go to ajusa.com and compare prices with other web sites, when I got my KYBs that was the cheapest i could find
post Jul 19, 2007 - 3:16 AM
chacha
Joined Dec 29, '05
From So-Cal
sorry about this but since we are on the topic, has anyone ever purchased these?
Or even heard of the brand in comparison to the Tein SS Damper-kit??? kindasad.gif
says:
Ksport Kontrol Pro
Toyota Celica (AT100/ST202) 94-99/Part #CTY050-KP/MSRP $1300
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
# 36-way adjustable dampening
# Made from high quality 6061 Aluminum with T6 for increased hardness
# Compression/Rebound adjustable
# Adjustable spring perch for height adjustment
# Adjustable body allowing maximum suspension travel
# Pillow Ball Top Mount w/ adjustable camber (not available for some models)
# Monotube High Pressure Design reduces oil leakage
# Electroplated body for protection from corrosion and rust
# One Year Limited Warranty
This post has been edited by chacha: Jul 19, 2007 - 3:18 AM
post Jul 19, 2007 - 5:45 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
Toyota part number for front sealed struts
48510-80219
48520-80045
post Jul 19, 2007 - 7:22 AM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(soven @ Jul 19, 2007 - 5:45 AM) [snapback]580157[/snapback]
48510-80219
48520-80045
thank you very much. and last but not least, how do i know if i have the "GT sport suspension"? would toyota know if i went to a dealer and looked it up on the computer or something by my VIN?
post Jul 19, 2007 - 8:36 AM
Culpable04
Joined Apr 17, '06
From New Jersey
yes, the dealer will know when they check your vin number. if you take your suspension apart you'll see that the front is a sealed shock instead of an sleeve with a strut like most people, if you have sealed shocks on front is sport susp. if it's a sleeve is regular.
post Jul 19, 2007 - 9:13 AM
LewFX
Joined Jan 28, '05
why buy from toyota when its the same product...find kyb cheaper online
post Jul 19, 2007 - 11:29 AM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(soven @ Jul 19, 2007 - 11:45 AM) [snapback]580157[/snapback]
48510-80219
48520-80045
Interesting. Anyone know the difference between these springs and which is best?
48131-2t140 frt spring
48131-2s740 frt spring - (305x156x177mm)
They are both for 6th gen Celicas with front sealed struts part numbers quoted by soven. The first is for a UK SR/ST with sports pack, the other is for the UK GT.
post Jul 19, 2007 - 2:43 PM
soven
Joined Mar 14, '05
I believe that the GT has stiffer springs and is better but it is just from memory so dont quote me on that smile.gif
post Jul 19, 2007 - 2:56 PM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
just a question a 94 GTS would have what in the front?? could someone post a pic of the sport suspension id like to know because on KYBs website the sealed (sport celica suspension) says for 95-99. Thanks guys
post Jul 19, 2007 - 9:27 PM
soven
Joined Mar 14, '05
ring toyota and give them your vin no. They will be able to tell you what you have. They look the same the last time i checked.
post Jul 20, 2007 - 9:22 AM
LewFX
Joined Jan 28, '05
just buy the full strut from kyb, price is practically the same as an insert and you dont deal with the hassle of inserts unless you upgrade to bilsteins
post Jul 20, 2007 - 10:42 AM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(LewFX @ Jul 20, 2007 - 9:22 AM) [snapback]580516[/snapback]
is this one? http://cgi.ebay.com/ebaymotors/KYB-GR-2-SH...sspagenameZWDVW
post Jul 20, 2007 - 12:19 PM
LewFX
Joined Jan 28, '05
read the description "(2 365092 front shocks, 2 334125-334126 Rear STRUTS)"
Lo-Fi Version Time is now: February 19th, 2025 - 9:54 PM
