![]() Enthusiast ![]() ![]() ![]() Joined Aug 25, '06 From HAMILTON NJ Currently Offline Reputation: 1 (100%) ![]() |
i need a 5sfe tranny. Mine took a crap on my and i only have 1,3,5 gears. It sucks not having reverse! Any1 around jersey have one?
go to Newark, there are like 5 junkyards one next to each other, one of them should have one. not from a Celica but maybe from a camry ( same tranny )
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) ![]() |
you sure its your tranny? if u only have 1,3,5 it might be your cables.
(a bunch of us have see it on an st185 alltrac, and an st185 swap celica) -------------------- ![]() Kawi Love |
and how can i tell if it is my cables?
remove the center console panels, and check to see if the cables are attached to your shifter. (both the side and the bottom) also shift the car into 2 and 4 when u have the console out, just to see what the cables are doing. Check onyour tranny to see if the cables are connected. If they are all connected, disconnect the ones on your shifter, and see if u pull on the end if it comes out (the cable inside might be broken)
QUOTE(2slow2nervous @ Jul 30, 2007 - 1:36 PM) [snapback]583718[/snapback] and how can i tell if it is my cables? well, think about it. there are 2 cables, and your only getting half your gears. seems like one of the cables is not doing its job. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Lo-Fi Version | Time is now: February 18th, 2025 - 3:40 PM |
