> No grip!, Celica spinnin wheels in 1st and 2nd, handles well round corners tho
post Aug 1, 2007 - 4:55 PM
sam-mubarak
Joined Jul 30, '07
From Lancashire, England, Uk
when setiing off from the lights, espesially in the wet, my celica just wheelspins badly, all the way up to the rev limit in 1st and sometimes also in 2nd! Ive tried 2 sets of tires and always have the same problem, and have never had this problem in any of my previous cars.what can i do to help stop this, and suspension mods? Its a basically standard st202 GT, check my profile for more info. Any help would be appreciated, Sam
Replies (1 - 19)
post Aug 1, 2007 - 5:09 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(sam-mubarak @ Aug 1, 2007 - 10:51 PM) [snapback]584425[/snapback]
Your main options are:
1. learn how to control your car through proper use of the accelerator (gas pedal) and clutch
2. fit an aftermarket traction control system, preferably one with launch control
You could alternatively attempt to fit a traction control system intended for another car, such as scrapped parts from an IS200, earlier or later gen or a Supra. But unless you really do your research you could end up making things worse rather than better going this route.
This post has been edited by BloodyStupidDavey: Aug 1, 2007 - 5:11 PM
post Aug 1, 2007 - 5:26 PM
sam-mubarak
Joined Jul 30, '07
I can get the car to grip throught proper use of the accelerator, but im from england, and its always raining here, and im gettin beat ijn the wet by much slower n less powerfull cars, juast because they grip. Are all st202s like this? The front end feels very light, but handles great round cornrs.
post Aug 1, 2007 - 5:37 PM
Culpable04
Joined Apr 17, '06
From New Jersey
you need to find better tires, I mean the tires you have they may be good but not for the the conditions you are. you need the best tires for raining. do some research about tires and you'll see the difference.
post Aug 1, 2007 - 5:43 PM
sam-mubarak
Joined Jul 30, '07
Will they really make all that difference? it seems really light at the front end, would lowering the front more than the back, or stiffening the suspension help?
post Aug 1, 2007 - 5:46 PM
daazndood
Joined Jun 5, '06
From Hayward,CA
QUOTE(sam-mubarak @ Aug 1, 2007 - 4:55 PM) [snapback]584428[/snapback]
your car is too powerful, shouda got an st.....
but on a serious note, how are you launching? obviosly if you floor it and drop the clutch you are gonna wheel spin, and since its raining you will wheel spin alot.
post Aug 1, 2007 - 6:05 PM
sam-mubarak
Joined Jul 30, '07
no i can set off fine, but even if i mput my foot down at 5000rpm, it spins up. I can b carefull and keep it grippin, but then u get overtaken and beat lol
post Aug 1, 2007 - 7:15 PM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
If you're talking about street-racing, quit while you're ahead unless you want to get your thread locked and the mods'll get all itchy.
And yes! Tires make everything! Well, that and a capable car...wait, you're in the UK! Get a GT-4!!! smile.gif
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
QUOTE(sam-mubarak @ Aug 1, 2007 - 6:05 PM) [snapback]584452[/snapback]
5000 rpm? so your talkin about racing, might wanna not talk about that, this will be locked for sure if you do
post Aug 1, 2007 - 7:59 PM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
Oh grow up guys. rolleyes.gif Just cause someone takes their car to 5K does not mean they're street racing. tongue.gif It could just mean he actually has some fun while driving.
How many miles on your car though? You're struts could be going. Even if not, stiffer ones could help. But I agree with everyone else, rubber should make the biggest difference. My GT's old and stock, and I spin a bit in the rain when accelerating hard, but not as bad as it sounds like you are. Lastly, not meaning any offense, but it really could be your driving. If you haven't raced a manual much(meaning on a track, to clarify for you nit-pickers tongue.gif), you could just be learning how to launch. Just a thought....
post Aug 1, 2007 - 8:21 PM
mneal2_92788
Joined Nov 7, '06
that kinda proves it the beat part that is
post Aug 1, 2007 - 8:30 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
first off your exhaust is huge! wider tires, better tires more suited for wet weather, and also slip the clutch a bit so you dont bog it and also so less power gets to the wheels, its gonna put some wear on the car but will help for launches when you need to pull out super fast
post Aug 1, 2007 - 8:54 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
maybe try getting tires that are all the same.
post Aug 1, 2007 - 10:14 PM
creis
Joined Jan 10, '04
From Shoreline, WA
I have similar issues in my GT very slick, and when autocrossing I have big issues when turning tends to slide straght when on the gas, with toyo proxi tires. you can try wider tires, but check alignment and camber, could be that your not getting the full tire flat and straght on the groud. can also try a softer compond tire but they ware faster.
post Aug 2, 2007 - 2:59 AM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE(creis @ Aug 2, 2007 - 4:14 AM) [snapback]584528[/snapback]
Good point. Also make sure all the tires are correctly inflated - under- or over-inflated tires will reduce your grip and you can't always tell just by looking at them. With factory-fitted wheels, the appropriate psi is usually 35 or 36 and is printed on the drivers' door jam. You'll need to adjust this value for aftermarket wheels.
post Aug 2, 2007 - 8:27 AM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
Who races in the rain anyways.??
post Aug 2, 2007 - 10:10 AM
learn how to drive?!
its a FWD car....if you don't know how to drive, and just floor it DUH the wheels are going to spin....if you are corning and don't have proper foot technique you are going to spin and understeer, crap it understeers no matter what..
its not a tire problem it be a drivin problem
edit: after looking at your profile......your wing is SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO BIG
maybe your just making mad tytes downforce that your lifting the front?!
This post has been edited by playr158: Aug 2, 2007 - 10:11 AM
post Aug 2, 2007 - 11:04 AM
Rayme
Joined Feb 18, '06
From NB, Canada
Get an LSD. should help ALOT
-Rémy
02 SiR, 08 250R
post Aug 2, 2007 - 11:33 AM
FortuneCookie
Joined Dec 12, '06
From Fob Sharana, Afghanistan
I use to have the same problem. Getting street performance tires helps alot. You can tell a major difference. Esp when speeding in the rain, you feel stuck to the road and not lifted and feel like your jet planing. And yes, aftermarket suspensions upgrade does help alot with traction. If you get adjustable coilovers, you can stiffen the back where as the rear springs won't lownch when you launch so most of the weight stays in the front and not the back where as traction pulls and not drags.
This post has been edited by FortuneCookie: Aug 2, 2007 - 12:46 PM
post Aug 2, 2007 - 11:42 AM
daazndood
Joined Jun 5, '06
From Hayward,CA
QUOTE(mneal2_92788 @ Aug 1, 2007 - 7:15 PM) [snapback]584483[/snapback]
i've hit 5000 rpm, even 6000 and it had nothing to do with racing.
Lo-Fi Version Time is now: December 1st, 2024 - 7:47 PM
