Enthusiast ![]() Joined May 6, '04 From Liverpool,UK Currently Offline Reputation: 0 (0%) ![]() |
Hi there guys,
i,ve rercently fitted a genuine momo steering wheel along with the correct momo boss kit on my jap import st205....the wheel looks and works fine but i now have a rather biggish gap around the boss/dash...and also my indicators fail to cancel out when i turn full lock.....i,ve spoken to momo and they reckon it,s normal because of the car being non uk and import model...apparently uk spec gt4,s are fine with same wheel etc??..anyone out there had similar problems?......is it something that can be fixed or do i just take it thats price to pay for owning import model!......thanks Guys any help appreciated. Ian |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) ![]() |
I've got an import GT & GT4 and they both have aftermarket steering wheel bosses but the indicators cancel fine mate.
By the gap I assume you mean the gap in the steering column housing? The GT also has a large gap between this housing and the boss, but the boss thats on the GT4 came with a collar that slides over the top and makes it wider, which hides the gap. Don't know if you can get them for momo bosses though. All I can think is if you wanted to get a bit of black plastic and make it a similar shape to the front of the housing but with a smaller hole cut in it so it masks the gap? As for the indicators, I think there should be something sticking out that knocks the indicator off as it passes (can't say for definite though as I've not taken one off before) Maybe theres something on your original one that should be put on before the new boss? |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) ![]() |
i got this problem b4 at first i thought its a wheel alignment..took me the whole day a re-align but didnt work also..anyway its rather simple.
take off ur steering wheel & hub... you will see the indicator cancellor (its the white round thing, try to turn the signal and u will see.) and realignment it to the middle then put on ur hub and steering wheel that should fix it ![]() This post has been edited by lubu: Aug 2, 2007 - 5:56 AM -------------------- ![]() 98% completion --- aaRon |
QUOTE(lubu @ Aug 2, 2007 - 11:54 AM) [snapback]584602[/snapback] i got this problem b4 at first i thought its a wheel alignment..took me the whole day a re-align but didnt work also..anyway its rather simple. take off ur steering wheel & hub... you will see the indicator cancellor (its the white round thing, try to turn the signal and u will see.) and realignment it to the middle then put on ur hub and steering wheel that should fix it ![]() Everything is alligned correctly all the grooves in the correct slots etc.....when the wheel and boss are removed i can switch on indicators then manually turn the collar with my hand to cancel the indication...just when the wheel and boss kit are on the car and are in as far as possible and as i say married up correctly it will not cancel inds........momo uk say its common problem with import gt4 using their bosses but i,m just getting other peoples ideas on the topic and to see if similar probs have arisen with momo wheels or similar....thanks |
hrms..i wouldnt think so..my friend has an gt4 and his works fine.
im not taking abt the grooves in the correct slot im talking abt the cancel dail or what ever you call it..its the white turnable thing that sits around the steering rod, when you turn the indicator and turn the wheel the indicator get cancelled if the dail sits in the correct spot otherwise you have to turn another half turn or so to cancel it.. This post has been edited by lubu: Aug 2, 2007 - 6:47 AM -------------------- ![]() 98% completion --- aaRon |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) ![]() |
i have a spearco wheel and it does the same thing i just deal with it lol
-------------------- ![]() BOOST GETS YOU LAID!!!! |
QUOTE(ianb @ Aug 2, 2007 - 12:36 PM) [snapback]584607[/snapback] QUOTE(lubu @ Aug 2, 2007 - 11:54 AM) [snapback]584602[/snapback] i got this problem b4 at first i thought its a wheel alignment..took me the whole day a re-align but didnt work also..anyway its rather simple. take off ur steering wheel & hub... you will see the indicator cancellor (its the white round thing, try to turn the signal and u will see.) and realignment it to the middle then put on ur hub and steering wheel that should fix it ![]() Everything is alligned correctly all the grooves in the correct slots etc.....when the wheel and boss are removed i can switch on indicators then manually turn the collar with my hand to cancel the indication...just when the wheel and boss kit are on the car and are in as far as possible and as i say married up correctly it will not cancel inds........momo uk say its common problem with import gt4 using their bosses but i,m just getting other peoples ideas on the topic and to see if similar probs have arisen with momo wheels or similar....thanks Like I said, I ain't got a problem with either import GT or GT4. I've got 2 different bosses and they both work fine. Send the momo boss back and get someone elses. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:46 PM |
