> Driver Turn Signal, Doesn't turn on with the light switch
post Aug 26, 2007 - 9:33 PM
Remy
Joined Jan 25, '06
From MN
Hey all, just a couple of minutes ago I had to run to the store (its dark out) I turned on my lights and notice my drivers side turn signal didn't come on I though maybe the bulb went out but when I use the turn signal the lights blinks !? But it doesn't come on when I turn on my lights ?? Check all the fuses looks fine any ideas what it could be ?? confused.gif
Replies (1 - 3)
post Aug 26, 2007 - 9:52 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
there are two filaments inside the bulb. mine did this. just replace the bulb and it iwll be fine. go ahead and replace both sides.
post Aug 27, 2007 - 4:47 PM
celicamike
Joined Dec 26, '05
From So Cal
QUOTE(mneal2_92788 @ Aug 26, 2007 - 9:52 PM) [snapback]591070[/snapback]
Exactly, it is a dual bulb. One filament is for your turn signal, the other for your running light. Just replace and you'll be fine, might as well do both sides while you're at it.
post Sep 2, 2007 - 11:06 PM
Remy
Joined Jan 25, '06
From MN
I took the bulb out and it looked fine but when I replaced it with another it worked just fine. <--Rhymes laugh.gif Thanks for the help !! thumbsup.gif
Lo-Fi Version Time is now: February 17th, 2025 - 3:33 PM
