dead cylinder |
dead cylinder |
Aug 29, 2007 - 5:05 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
so my car was strapped on the dyno and the tuner was adding fuel to my #2 cylinder and it wasn't responding. so as the car was runnign we took the spark plug wire off and noticed the engine idle didn't change...after pulling the plug out and seeing it was fine and was getting spark and was wet for the injector; we did a comression check on it and....yep nothing. did a leak down test at 100 psi and it was hissing throgh the oil cap. so i figure it as either bad rings, or a cracked ringland beacuase there is oil smoke when the engine is under load coming out of the breather tube on the valve cover. I was talking to some of my buddis and was told it could be a burnt valve, but i can't see that being the case becuase wouldn't the smoke exit out of the exhaust manifold? i'm gonna be pulling the head off prob sat or sun and i hope not to see any more damage than i am expecting.
Aug 29, 2007 - 5:19 PM |
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
QUOTE(rjbibeau @ Aug 29, 2007 - 5:05 PM) [snapback]591938[/snapback] so my car was strapped on the dyno and the tuner was adding fuel to my #2 cylinder and it wasn't responding. so as the car was runnign we took the spark plug wire off and noticed the engine idle didn't change...after pulling the plug out and seeing it was fine and was getting spark and was wet for the injector; we did a comression check on it and....yep nothing. did a leak down test at 100 psi and it was hissing throgh the oil cap. so i figure it as either bad rings, or a cracked ringland beacuase there is oil smoke when the engine is under load coming out of the breather tube on the valve cover. I was talking to some of my buddis and was told it could be a burnt valve, but i can't see that being the case becuase wouldn't the smoke exit out of the exhaust manifold? i'm gonna be pulling the head off prob sat or sun and i hope not to see any more damage than i am expecting. It sounds like you may have a blown head gasket. It may be blown between the oil return and the #2 cylinder. This post has been edited by toyotacrazy: Aug 29, 2007 - 5:20 PM |
Aug 29, 2007 - 6:47 PM |
this would probably be the reason for it. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 29, 2007 - 7:08 PM |
QUOTE(lagos @ Aug 29, 2007 - 7:47 PM) [snapback]591967[/snapback] this would probably be the reason for it. seeing that pic, right above your sig, art, tells the whole story. ringland or cracked piston would be my guess as well. too much heat, my friend. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Aug 29, 2007 - 7:30 PM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
OMG!!! NO INTERCOOLER!!!!!
Say bye-bye to the pison ringlands, it ran too hot and they broke! |
Aug 29, 2007 - 8:16 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
QUOTE(lagos @ Aug 29, 2007 - 4:47 PM) [snapback]591967[/snapback] this would probably be the reason for it. man that was a solid explanation. Find the problem, fix the leak, then get your self an intercooler and go easy on the boost and this shouldnt happen again. |
Aug 29, 2007 - 8:17 PM |
Enthusiast Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
im pretty sure thats his old setup before the seals went out on his ct26. Im pretty sure he has an intercooler now.
-------------------- -Brian
Aug 29, 2007 - 8:28 PM |
QUOTE(Celiracer18 @ Aug 29, 2007 - 9:17 PM) [snapback]591998[/snapback] im pretty sure thats his old setup before the seals went out on his ct26. Im pretty sure he has an intercooler now. dont mean the damage wasnt done before.. -------------------- Former Team 5SFTE pro member ;)
Aug 29, 2007 - 8:30 PM |
yeah i suppose. BTW where you getting it tuned Rick?
Aug 31, 2007 - 12:22 PM |
QUOTE(95celgt @ Aug 30, 2007 - 12:30 AM) [snapback]591982[/snapback] OMG!!! NO INTERCOOLER!!!!! Say bye-bye to the pison ringlands, it ran too hot and they broke! those are old pics that was for the inital start up like last year. i custom did my own FMIC QUOTE(Celiracer18 @ Aug 30, 2007 - 1:30 AM) [snapback]592001[/snapback] yeah i suppose. BTW where you getting it tuned Rick? it was at Modern automotive performance in plymoth....very knowledgeable group i'll post up new pics of my new setup tonight probably and sunday i'll be tearing her down. This post has been edited by rjbibeau: Aug 31, 2007 - 12:19 PM -------------------- |
Aug 31, 2007 - 12:28 PM |
how's your project going celiracer?
QUOTE(toyotacrazy @ Aug 29, 2007 - 10:19 PM) [snapback]591944[/snapback] QUOTE(rjbibeau @ Aug 29, 2007 - 5:05 PM) [snapback]591938[/snapback] so my car was strapped on the dyno and the tuner was adding fuel to my #2 cylinder and it wasn't responding. so as the car was runnign we took the spark plug wire off and noticed the engine idle didn't change...after pulling the plug out and seeing it was fine and was getting spark and was wet for the injector; we did a comression check on it and....yep nothing. did a leak down test at 100 psi and it was hissing throgh the oil cap. so i figure it as either bad rings, or a cracked ringland beacuase there is oil smoke when the engine is under load coming out of the breather tube on the valve cover. I was talking to some of my buddis and was told it could be a burnt valve, but i can't see that being the case becuase wouldn't the smoke exit out of the exhaust manifold? i'm gonna be pulling the head off prob sat or sun and i hope not to see any more damage than i am expecting. It sounds like you may have a blown head gasket. It may be blown between the oil return and the #2 cylinder. good thinking...never thought of that one -------------------- |
Aug 31, 2007 - 8:51 PM |
Enthusiast Joined Aug 30, '07 From Belle Plaine Currently Offline Reputation: 0 (0%) |
Try droppin a 3s....haha i have one! j/k
love you |
Aug 31, 2007 - 10:44 PM |
i like my lil 5s thank you very much
Aug 31, 2007 - 10:55 PM |
my project is pretty dead. im selling some of the stuf for other things and rebuilding a new motor (with some goodies) since mines questionable to say the least. i may even sell it all for a 3S ill have to see.
Aug 31, 2007 - 11:19 PM |
QUOTE(rjbibeau @ Aug 31, 2007 - 10:44 PM) [snapback]592544[/snapback] i like my lil 5s thank you very much Haha ill agree with that your LIL 5s...it cant handle the rath of the turbo like the 3s can! teehhheee See even your friend here is getting a 3s |
Sep 1, 2007 - 7:19 AM |
QUOTE(mr2nerkitty @ Sep 1, 2007 - 12:19 AM) [snapback]592551[/snapback] QUOTE(rjbibeau @ Aug 31, 2007 - 10:44 PM) [snapback]592544[/snapback] i like my lil 5s thank you very much Haha ill agree with that your LIL 5s...it cant handle the rath of the turbo like the 3s can! teehhheee See even your friend here is getting a 3s i find this laughable. ive seen more than a few 3s blown motors since ive had my 5sfte (2 yrs, over 30k ) -------------------- Former Team 5SFTE pro member ;)
Sep 1, 2007 - 9:00 AM |
thats cause you're a pro Manny and you did it right and did your research ahead of time. Something i wish i spent more time doing
Sep 1, 2007 - 9:47 PM |
QUOTE(rjbibeau @ Aug 31, 2007 - 12:28 PM) [snapback]592442[/snapback] how's your project going celiracer? QUOTE(toyotacrazy @ Aug 29, 2007 - 10:19 PM) [snapback]591944[/snapback] QUOTE(rjbibeau @ Aug 29, 2007 - 5:05 PM) [snapback]591938[/snapback] so my car was strapped on the dyno and the tuner was adding fuel to my #2 cylinder and it wasn't responding. so as the car was runnign we took the spark plug wire off and noticed the engine idle didn't change...after pulling the plug out and seeing it was fine and was getting spark and was wet for the injector; we did a comression check on it and....yep nothing. did a leak down test at 100 psi and it was hissing throgh the oil cap. so i figure it as either bad rings, or a cracked ringland beacuase there is oil smoke when the engine is under load coming out of the breather tube on the valve cover. I was talking to some of my buddis and was told it could be a burnt valve, but i can't see that being the case becuase wouldn't the smoke exit out of the exhaust manifold? i'm gonna be pulling the head off prob sat or sun and i hope not to see any more damage than i am expecting. It sounds like you may have a blown head gasket. It may be blown between the oil return and the #2 cylinder. good thinking...never thought of that one Yea but its just something to look for. You may as well put rings in it. If your going that far why not put better rods in it....and so on .....haha its so addicting |
Lo-Fi Version | Time is now: December 2nd, 2024 - 4:32 AM |
