> Metal friction sounds, coming from my wheel
post Sep 8, 2007 - 9:08 PM
NaderG
Joined May 13, '07
From riverside, ca
When i drive in a narrow street i can hear a churning metal sound coming from my rear left wheel ... what is that ? and how to fix it ? .... i am a big noob but can it be the wheel bearing ? or like the brakes are stuck somehow ?
Replies (1 - 25)
post Sep 8, 2007 - 9:50 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
does it vibrate at higher speeds? and if you jack up the car can u wiggle the wheel.
if those are yes to all my questions - wheel bearing
post Sep 8, 2007 - 9:56 PM
NaderG
Joined May 13, '07
From riverside, ca
vibration : i will not feel any vibration because it is the rear wheel , i will jack up the car tomorrow and try the wiggle wheel method ..... any other things it might be ? and how hard is it to change a wheel bearing ? what kind of tools needed etc.. thansk
post Sep 8, 2007 - 10:28 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
could also be the heat shield for the rotors rubbing against the rotors while driving.
post Sep 8, 2007 - 10:33 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
take a look at everyting back there...
make sure the lug nuts are on good and tight
check how much brake pads you have left (on both sides of the rotor)
and do the wiggle test.
post Sep 8, 2007 - 10:51 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
mine did similar, check brake pads
post Sep 8, 2007 - 11:48 PM
NaderG
Joined May 13, '07
From riverside, ca
This will sound stupid : how do i check the brake pads , i dont have the lil gauge that goes into the inspection hole ( or whatever its called) ..... what kind of signs should i look for on the pad ? i will try to look in y repair manual on how to get the pads out , if i get confused i will ask you guys , thanks for the help.
post Sep 8, 2007 - 11:54 PM
mneal2_92788
Joined Nov 7, '06
jack up the rear of the car, remove wheel. remove teh lower bolt on the back of the caliper, twist the caliper up. remove brake pads.
or just take the wheel off and look at the brake pads w/ the caliper on. there should be no less than 1/8" of pad left. or else it is time to change.
post Sep 9, 2007 - 10:30 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
you can always come and see me, i can help you out with most suspension related problems.
post Sep 9, 2007 - 10:41 AM
ShadowSX
Joined Sep 9, '07
From Lithuania
I had the same problem. Brakes were not releasing properly because of corosion of the brake cylinder. If the wheel is not spinning easily, this may be your problem. I had to replace the old cylinder with a new one and now the sound is gone.
post Sep 9, 2007 - 10:48 AM
NaderG
Joined May 13, '07
From riverside, ca
QUOTE(ShadowSX @ Sep 9, 2007 - 3:41 PM) [snapback]594612[/snapback]
How much does a brake cylinder cost ?
and thanks LewFX , i appreciate your help
post Sep 9, 2007 - 10:49 AM
LewFX
Joined Jan 28, '05
master cylinders are expensive bout 100 bux
http://pa.partsandaccessories.com/parts/pa...der&dp=true
This post has been edited by LewFX: Sep 9, 2007 - 10:51 AM
post Sep 9, 2007 - 10:58 AM
NaderG
Joined May 13, '07
From riverside, ca
well , i will jack up the car in a moment and take a look at the pads , if the master cylinder is bad , then shouldn't the noise be coming from more than one wheel ?
This post has been edited by NaderG: Sep 9, 2007 - 11:02 AM
post Sep 9, 2007 - 12:19 PM
NaderG
Joined May 13, '07
From riverside, ca
just finished my inspection , the wheel does not jiggle , the pads are still huge .... that only leaves the master cylinder malfunction ..... i will not bother with it until i am sure that i will either do or not do a swap ... because if i do a swap , it will come with the clip
post Sep 9, 2007 - 4:17 PM
LewFX
Joined Jan 28, '05
the wheel doesnt have to jiggle for a bad bearing. my front bearing was toasted...wheel didnt wiggle but made a noise. a bad bearing can also cause the rotors to overheat and warp.
post Sep 9, 2007 - 6:09 PM
NaderG
Joined May 13, '07
From riverside, ca
QUOTE(LewFX @ Sep 9, 2007 - 9:17 PM) [snapback]594672[/snapback]
what do you mean by Warp ? ... i doubt its my Master cylinder , simply because the car has 100K right now ... this is a Toyota , bigs things shouldnt be going out now .... i kind of think its the bearing ..... so how do i check it ?
post Sep 9, 2007 - 8:23 PM
LewFX
Joined Jan 28, '05
take tire off, use lug nuts to tighten rotor...with a jack stand, place pencil on rotor and spin it and see if it stays on rotor or if it skips.
post Sep 9, 2007 - 9:11 PM
NaderG
Joined May 13, '07
From riverside, ca
i will do that next weekend
post Sep 9, 2007 - 9:55 PM
it could be your e brake shoes. When they wear, they make a sort of squealing noise. does you e brake handle go all the way up ? does it stop/hold the car well ?
post Sep 9, 2007 - 10:04 PM
NaderG
Joined May 13, '07
From riverside, ca
hmm , well , the E-brake does hold the car in place , even on really steep incline , but it squeals all the time ... like when i get in the car , the lil motion i cause makes it sequel .... ... but i dont understand how this will make a sound during driving with the e-brake down
post Sep 10, 2007 - 5:26 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
just shot my brakes with brakleeen thingy and the noise went away
post Sep 10, 2007 - 5:43 PM
NaderG
Joined May 13, '07
From riverside, ca
QUOTE(808celica @ Sep 10, 2007 - 10:26 AM) [snapback]594839[/snapback]
Could u be a bit more specific ...
post Sep 11, 2007 - 11:01 PM
NaderG
Joined May 13, '07
From riverside, ca
post Sep 12, 2007 - 12:04 AM
mneal2_92788
Joined Nov 7, '06
brake cleaner. just spray it on the rotor, and the pad
post Sep 12, 2007 - 12:18 AM
NaderG
Joined May 13, '07
From riverside, ca
QUOTE(mneal2_92788 @ Sep 12, 2007 - 5:04 AM) [snapback]595321[/snapback]
thank you , do i need to take the pad out and spray on it ?
post Sep 12, 2007 - 1:38 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE(NaderG @ Sep 12, 2007 - 5:18 AM) [snapback]595326[/snapback]
i didnt but would recommend if the noise is really bad. and sorry for not being clear.....the name on the spray can was "brakleeen"
^^^^ see i was some what clear laugh.gif i remembered the name on the can laugh.gif
Lo-Fi Version Time is now: February 17th, 2025 - 8:35 AM
