Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) ![]() |
like the title says... I am thinking of upgrading to one of the walbro 255 pumps and i was wondering if i had to upgrade anything else at the time or if the ecu will detect the upgrade automatically? likewise, would this be a good time to add a fuel pressure regulator?
oh and on another note.. I am planning on doing a oil relocation kit w/oil cooler. details about what i need to do this? instructions and example stuffs i need to pull this off would be great. thank you. -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) ![]() |
Are you running a turbo? No point in just getting a walbro unless you have big plans later. Even then your injectors are still going to flow the same amount of fuel as before.
Fuel pumps are a awsome upgrade WITH others. -------------------- Member of Team 5sfTe
thanks for the advice. no i'm not running a turbo right now, but i'm doing an engine swap and then turbo'ing.. thanks again.
advice on the oil stuffs? -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:29 PM |
