> Replacing factory tweeters, Will this work?
post Oct 8, 2007 - 5:11 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I have some JBL tweeters and I was wondering if I could replace the factory ones with these. Here are some pictures of how big they are and the plug they use, could these by plug and play?
-Matt
This post has been edited by GotToyota: Oct 8, 2007 - 5:18 PM
Replies (1 - 3)
post Oct 8, 2007 - 5:13 PM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
let me know if it works cause i need new ones... i cant play high range stuff cause they crackle
"You should take a short walk on a LONG PIER"-Crazy Steve
My Celica's SRI
post Oct 8, 2007 - 8:58 PM
toyocelgt95
Joined Aug 19, '07
From new providence P.A.
you shud be able to just remove the old tweeters and cut the wires and wire the new ones right up with out a broblem as long as the tweeters you got have the corect whole in the back to mount to the bracket.
post Oct 9, 2007 - 10:19 AM
Valo666
Joined May 15, '05
From Toronto
thouse dont look like they will work. The ones i replaced mine with look like this.
you need to get a tweater thats 1" or smaller and it needs to be abel to mount in the rear by a single bolt. Also, when replacing the tweaters, your gonna need to dremil out part of the tweater cover to allow for the bigger speaker grill.
Lo-Fi Version Time is now: February 22nd, 2025 - 2:16 AM
