Enthusiast ![]() Joined Sep 13, '02 From BC, Canada Currently Offline Reputation: 0 (0%) ![]() |
everyone is always asking about the 3sgte swap and about the AWD conversion, but does anyone know what kind of 1/4 mile times the fully swapped FWD celicas pull? also, how much would a completely swapped celica weigh? stock ST204s are famous for their light weight and handling capabilities, but does this still hold true for post swap celicas?
i'm just in a thinking mood today i guess ![]() ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) ![]() |
the 3sgte does not weigh too much more than a 5sfe, it is the same series block
as for times, i dont know of anyone that has taken a fwd 3sgte celica to a track. my guess is 14's with a stock 2nd gen 3sgte. but it will depend on the driver, with that much power it will be very easy to screw up your launch -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
true enough... i'm with you on this one, but that's just my super inexperienced guess ![]() is the ST185 really not that much heavier than the 5sfe? hmmm... i guess it is negligeble when you add how much power difference there is ![]() what about if the 3sgte wasn't stock? could it drop blow 14 sec with bolt ons and other misc modifications? -AJ |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) ![]() |
I think a swap would easily do high 13s with a good driver and proper setup. My car weighs 2400lbs right now, I don't think it would be very difficult to maintain that weight in post swap condition. Ask again in 6 months and I'll probably be able to tell you.
well, the thing is, you can do the basic mods and up the boost(and disable the fuel cut) and make a lot more power. but then it would be very very hard to get traction. but from a rolling start it would kill most cars on the road. -------------------- 1994 Celica GT4 WRC Edition
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 10, '03 From Connecticut Currently Offline Reputation: 11 (100%) ![]() |
You gotta go reallly really easy at start - the swapped 3sgte's have no LSD and therefore you spin, alot.
ooh, that kinda sucks... i'm all about the fast starts
![]() sigh... i suppose there aren't any ways around this unless you put super grip tires up front eh? unless there is a way around this that i'm not thinking of ![]() |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
Did any of the trannies that were mounted up to a 3S-GE(ST202/3 Celica, Curren, Altezza, etc.) come with a LSD? If so, you could probably swap in one of those trannies fairly easily and then you'd be able to get better traction off the line.
![]() -------------------- New Toyota project coming soon...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
the curren 3sge trans had LSD i believe. and i would say the 1/4 times should be in the high 14s. cuz if you measure it up against a mr2 which does a 1/4 in 14.6. if you take into account mid engine RWD and the 400 LBS weight difference, the 2 should come out fairly even, but i couldnt see a swapped celica winning. of course im speaking with no mods performed to either car besides the 2nd gen 3sgte swap with all factory parts. if it was a 3rd gen swap with LSD i could definalty see a swapped celica taking out a stock MR2t.
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
that's one way around the tire spin and it would save people from having to look for the rare camry v6 tranny ![]() oh and by the way, did you get my e-mails coomer? i never got a reply to any of them about the group buys ![]() This post has been edited by AJcelica: Aug 12, 2003 - 2:03 PM |
Enthusiast ![]() Joined Aug 30, '02 From tacoma WA Currently Offline Reputation: 0 (0%) ![]() |
i think only one guy in a 6th gen with a st185 motor has done the 1/4 mile.
he pulled a 14.2 |
14.2 is pretty quick, and I'm guessing that you could break into the 13s fairly easily with that engine and some basic bolt-on mods.
And to AJCelica, I think I got your last email, but I'm not sure what happened to it. Could you maybe resend it to me? -------------------- New Toyota project coming soon...
wow 14.2 is quick! and that was stock, just engine swap?
coomer: absolutely ![]() |
Enthusiast ![]() Joined Jun 26, '03 From Los Angeles Currently Offline Reputation: 0 (0%) ![]() |
Ask TRD. They made a LSD for 6GC st204's so it is likely they make one able to be swapped!!!
Enthusiast ![]() ![]() Joined Oct 9, '02 From Longmont, CO Currently Offline Reputation: 1 (100%) ![]() |
Dont think the Altezza tranny would work seeing as how it is RWD! |
Probably not. I didn't even think about that. ![]() -------------------- New Toyota project coming soon...
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) ![]() |
When you swap the 3sgte you'll have to use a different tranny, the 5sfe tranny will bolt up and so will the tranny from the V6 camry. TRD makes a LSD for the 5sfe.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) ![]() |
I know a guy that gets 12s. jhull at toyotacelicas.com. He's got a 5th with a 3sgte swap...not a awd conversion.
-------------------- 95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE 02 WRX --> This is for speed - Borla Exhaust - TurboXS BOV - Custom CAI 02 Civic EX - MB Quart Reference 5.25" Components - Rockford MTX 8" Subs in the doors - Alpine Type S Rear Fills - 2x Alpine SWR-1042D Subs in a custom fiberglass box - Alpine F345 Amp for the front doors - Alpine M605 on each Type R - Phoenix Gold wiring - Alpine CDA-9855 Head Unit - Alpine Amp link - 2x Rockford Fosgate 1 Farad Caps - The best Viper 791 alarm install ever |
Don't forget that traction control is a possibility. Its really very simple when using an aftermarket ecu (like the autronic that I'll be going with). Its just a matter of adding some wheel speed sensors and telling the computer whats up.
With traction control thats properly tuned and an LSD a swap will do mid 13s easy. The comparisons with the mr2 are not really valid as it weights a lot more, 4-500lbs more. The general rule of thumb is 100~0.1sec. FWD is a bit of a disadvantage when its not set up right, but it can be made to work quite well. Get some drag radials, spring for the lsd (at least a phantom grip, they're really cheap. Get a quaife if you have some dough), and you're in the 13's deep. Just because its not easy and cheap doesn't mean its not possible! |
Lo-Fi Version | Time is now: February 21st, 2025 - 1:15 PM |
