> 3vz-fe rebuild. Have a question
post Oct 17, 2007 - 9:55 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
I just pulled this motor out of a 92 Camry from the yard. I got the motor at the house and start stripping it apart. I found out that they did the timing totally wrong. When I got the pulley to TDC 0, both of the cam circle points down when it's suppose to be up.
I measured the cam and crankshaft play and met manufacture specs. I found 1 blown piston and the rest are okay. Now looking at the picture is this head reuseable? and what do you recommend?
IPB Image <--- I miss :'' (
Replies (1 - 15)
post Oct 17, 2007 - 10:13 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
nope the head is toast man, all that roughness in the chamber will be hot spots and the valves are toast. might be easier for ya to find another longblock thats in good condition to start from. unless you know what your doing. but then again you probably wouldnt be asking us for help. lol jk man
post Oct 17, 2007 - 10:59 PM
kerosene
Joined Jul 4, '07
From US
cant be boared out?
post Oct 17, 2007 - 11:14 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yeah. timing is kinda hard. i helped my friend rebuild a acura Integra engine, ane while i was out buying sparkplugs. he put the head on and didn't align anything, AND there were no timing marks on the crank pulley. so i had to figure that out. the first time we tried to crank it, it sucked on the exhaust side and blew out the intake.. anyway it runs now.
you putting the 3VZ in your celica??
post Oct 17, 2007 - 11:42 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
i'm not sure weather to put it in the celi or in the mr2. I have other plans for the celi. I never encounter this before so that's why I wouldnt know.
post Oct 18, 2007 - 1:24 AM
Hanyo
Joined Aug 16, '03
From Bay area
are any of the valves bent?
any signs of the the valves making contact with the pistons?
If nothing has gone wrong, it should be rebuild-able.
post Oct 18, 2007 - 11:20 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i say Celica it:)
im planning this swap for mine.
post Oct 18, 2007 - 11:48 PM
if all 4 valves in that chamber are flush (none sunken in) then the spark plug may have broken off and bounced around inside there. if one is sunken into the head deeper than the others then its likely you dropped a valve seat.
post Oct 19, 2007 - 3:14 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
oh yeh and one more thing, i remove the head bolts from different sequence that i should remove it, Will anything happen or will it be just fine if i put it back on w/ the right sequence?
post Oct 19, 2007 - 11:45 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
QUOTE(Bitter @ Oct 18, 2007 - 11:48 PM) [snapback]606453[/snapback]
the valves are all flushed and spark plug was fine. I think it was detonation from timing being installed wrong..
I must just have to pull another VZ out of the yard.
post Oct 19, 2007 - 6:46 PM
nah, that looks like something got in there and bounced around.
post Oct 21, 2007 - 8:33 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
Bitter, i believe you're right. So, I went to the yard and got another 3vz for $20, this one is in great condition. The weekend is over so I'll have to wait till next weekend to work on it.
post Oct 21, 2007 - 8:35 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
what yard are you going to?
post Oct 21, 2007 - 8:48 PM
QUOTE(My2Celi @ Oct 21, 2007 - 8:33 PM) [snapback]607083[/snapback]
hang onto the ****ty one for parts wink.gif or keep it to build and swap into the mr-2 later on.
post Oct 22, 2007 - 1:22 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
you pull it, it's in grand prairie, tx. There's another place call awesome and it's any motor for $50 and tranny for $25 bucks but both place requires you to pull it yourself. biggrin.gif. I'll try to update this project as much as possible.
post Oct 22, 2007 - 11:59 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i should go there lol
Lo-Fi Version Time is now: November 29th, 2024 - 11:14 PM
