> Optima Battery / Red or Yellow Top, What do you have?
post Oct 23, 2007 - 9:42 AM
cv7713
Joined Sep 21, '07
From FL
I am going to buy an Optima battery but am unsure which one to get. Is the red top sufficient? I am also installing a 170 amp high output alternator.
What is the difference between to two batteries? Cranking amps?
Do you like yours?
Replies (1 - 19)
post Oct 23, 2007 - 9:59 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
I have red but yellow is better for electronics, but is a bit more expensive frown.gif I used to kill every normal battery but my redtop keeps up really well with the subs and all of the power being drawn... I'd go yellow if u have the $$ though and are planning on a big system
post Oct 23, 2007 - 11:49 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
I have a yellow top... deep cycle batteries are really good if you have your system on when your car isn't... i loved mine when i had my system in... but now without the system, it's just another battery frown.gif
post Oct 23, 2007 - 11:53 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Were talking like 140-200$ batteries here. Where do you guys get the money to buy such expensive batteries.
post Oct 23, 2007 - 12:26 PM
cv7713
Joined Sep 21, '07
From FL
lol.... yes, but they last twice as long as a regular battery which is $50-70 (x2 $100-140). plus the advantages of the optimas... you need to see if it is worth it personally. I am a electronic fanatic and the importance of a good battery, alternator, and wiring is priceless! laugh.gif
post Oct 23, 2007 - 12:50 PM
kerosene
Joined Jul 4, '07
From US
I got a gold top... a lot more expensive but 8 year warranty
post Oct 23, 2007 - 5:53 PM
Jaws4God
Joined Mar 27, '04
This post has been edited by Jaws4God: Oct 23, 2007 - 5:54 PM
post Oct 23, 2007 - 6:26 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(soulshadow @ Oct 23, 2007 - 9:53 AM) [snapback]607648[/snapback]
because optima's are a different kind of battery then a conventional one. They are leak proof and could even be mounted upside down, they don't make any hydrogen emissions which means they won't corrode battery terminals and won't explode if you accidentally get a spark to close to them, they last twice as long, and they are able to make more cold-cranking amps with a smaller battery. only downside is they are a little denser so they have a little more weight to them, but since you're using a smaller battery then the weight probably evens out to what you would expect a conventional battery with 800 CCA to weigh.
anyway, yellow top is a deep-cycle battery which means it's more durable to being drained and then recharged. which would be good if you plan on using your stereo while the car isn't running.
post Oct 23, 2007 - 11:01 PM
tim86
Joined Oct 31, '03
QUOTE(kerosene @ Oct 23, 2007 - 1:50 PM) [snapback]607668[/snapback]
what type of gold top because optima doesnt make one?
post Oct 23, 2007 - 11:03 PM
kerosene
Joined Jul 4, '07
From US
Its for a Dodge Ram, ill try to find it... had to get it directly from them was a special battery has like 800 cranking amps...
post Oct 23, 2007 - 11:48 PM
why are you getting a 170 amp high output alternator ?
post Oct 24, 2007 - 1:27 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Batman722 @ Oct 23, 2007 - 9:48 PM) [snapback]607881[/snapback]
probably to run a huge sound system without draining the battery even with the car running.
post Oct 24, 2007 - 1:42 AM
kerosene
Joined Jul 4, '07
From US
QUOTE(6strngs @ Oct 24, 2007 - 1:27 AM) [snapback]607898[/snapback]
Yep, most likely... i've installed a 250 on a competition civic before... that **** was pulling about 4k watts on system... one of the more powerfull ones ive installed....
post Oct 24, 2007 - 7:18 AM
cv7713
Joined Sep 21, '07
From FL
correct. here's a good article:
http://www.termpro.com/articles/electsys.html
post Oct 25, 2007 - 10:24 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
ive had both....not a huge difference
BOOST GETS YOU LAID!!!!
post Oct 25, 2007 - 12:57 PM
kerosene
Joined Jul 4, '07
From US
QUOTE(jesterwr217 @ Oct 25, 2007 - 10:24 AM) [snapback]608278[/snapback]
there is, one lasts longer than other... from what they told me the redtop doesnt last as long since its made of different properties
post Oct 25, 2007 - 1:28 PM
QUOTE(soulshadow @ Oct 23, 2007 - 12:53 PM) [snapback]607648[/snapback]
best part is the warranty on them. redtop is 3yrs, in store replacement. seeing as how most batteries only last 2yrs, you just go back and get a new one if when it dies, and your 3yr warranty starts all over again. i already replaced mine once when i killed it by running the car with no alt for 2hrs.
post Oct 25, 2007 - 2:13 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I hope this doesn't count as a thread jack...
I looked up Optima for my car on their site and Autozone, and search results were 0. Where can you buy these? Who carries them?
post Oct 25, 2007 - 2:34 PM
zero07
Joined Apr 15, '07
From san antonio tx.
Costco!
post Oct 25, 2007 - 2:40 PM
GriffGirl
Joined Feb 7, '07
QUOTE(zero07 @ Oct 25, 2007 - 12:34 PM) [snapback]608352[/snapback]
Costco!
Suh-WEET!
Lo-Fi Version Time is now: November 28th, 2024 - 2:57 AM
