![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 8, '06 From Nova Scotia, Canada Currently Offline Reputation: 1 (100%) ![]() |
Hey all,
jumped into the CeliPig last thursday after a moonlight gig and noticed everything was a little dim. After being "flashed" by numerous oncoming cars i stepped out to check the headlights. lo and behold! both lo-beams were off. still have running lights, still have interior lights and even still have foglights (that's how i got home). checked the fuses-- both left and right lo-beam fuses are good. i can hear the relay clicking but still no lo-beams. is there an easy way to test the relay before i spend 122.65$ for an after-market replacement only to find out it's not the problem. do you know how much beer you can buy for 122.65$ ?!?!? so any help will be useful. -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 10, '03 From Connecticut Currently Offline Reputation: 11 (100%) ![]() |
Did you check the bulbs?
![]() Enthusiast ![]() ![]() ![]() Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(Supersprynt @ Oct 25, 2007 - 1:13 PM) [snapback]608236[/snapback] Did you check the bulbs? x2 -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(cHinaman727 @ Oct 25, 2007 - 1:33 PM) [snapback]608241[/snapback] QUOTE(Supersprynt @ Oct 25, 2007 - 1:13 PM) [snapback]608236[/snapback] Did you check the bulbs? x2 Shoot X3 This post has been edited by frosty: Oct 25, 2007 - 10:26 AM -------------------- ![]() CLOSED on 25 acres! -shop coming soon.... |
QUOTE(frosty @ Oct 25, 2007 - 12:26 PM) [snapback]608280[/snapback] QUOTE(cHinaman727 @ Oct 25, 2007 - 1:33 PM) [snapback]608241[/snapback] QUOTE(Supersprynt @ Oct 25, 2007 - 1:13 PM) [snapback]608236[/snapback] Did you check the bulbs? x2 Shoot X3 DUH!! no. i assumed since they both went out EXACTLY at the same time it was something else. the only thing i know that might burn them both at once is an electrical surge or short-circuit. the fuses should have blown too. i will check ASAP. so much for my troubleshooting skills ![]() -------------------- ![]() |
It could be something else, the coincidence is strong. But you always start with the simplest explanation.
QUOTE(Supersprynt @ Oct 25, 2007 - 4:45 PM) [snapback]608360[/snapback] It could be something else, the coincidence is strong. But you always start with the simplest explanation. i finally got my hands on the CeliPig on Saturday morning. the left bulb was a mess. the filament was totally demolished...dozens of pieces and a blast mark inside the bulb. the right bulb looked OK, but the filament was showing "OPEN" on the meter. i guess i'll stick with the basics and do my troubleshooting from A to Z without making assumptions. we all know what happens when you assume, don't we?!? ![]() -------------------- ![]() |
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:40 PM |
