> Water pump out, what else to replace?
post Oct 28, 2007 - 10:49 PM
99GT
Joined Dec 14, '06
From MN, USA
While I'm at it what else should I do?
Water pump
Water pump gasket
Timing belt?
Drive belt?
Valve cover gasket?
Spark plugs, wires.
This suck ass. Death in family, Water pump. ****ty weekend. I'm so bummed.
Replies (1 - 6)
post Oct 29, 2007 - 1:45 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Sorry for your loss...
Definitely replace the timing belt, it's pretty standard to replace that when the water pump gets replaced so you only have to open it up once.
As for other stuff, might as well at least do plugs/wires/cap/rotor stuff so you can keep track of when everything was done. If the other gaskets don't need to be done, I'd leave 'em alone, but if you're gonna open everything up to inspect it you might as well just replace while you're in there. Just my opinion.
post Oct 29, 2007 - 1:52 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Typically you would just do the timing belt along with the water pump, but I guess it depends on how long its been since the last tune up.
If it's been a while I would replace the plugs for sure, if you don't want to replace the distributor I would pop it off and clean the leads inside. Make sure you put it back on properly.
**** Photobucket
post Oct 29, 2007 - 6:06 PM
beno
Joined Nov 22, '05
From New Zealand, Hamilton
timing belt
waterpump
idlers
tensioners
power steering belt
altinator belt
cam seals if possible
altinator belt bearing (not hole unit as thats way to expensive an unnecessary- just punch bearing out and buy a new one from a bearing place, take bearing into shop)
with all that replaced youll be sweet and youll have no squeeks anywhere
change all gaskets that you get given
and use gasket liquid glue for water pump gaskets! get from car shop
make sure you use loctite for the bolts! esp crank bolt and idler and tensioner bolts
do everything because you dont want to go back into this area more than once- i did my cambelt myself and it sure is a tricky area but then again ive never done anything like that before
This post has been edited by beno: Oct 29, 2007 - 6:13 PM
post Oct 30, 2007 - 12:38 PM
99GT
Joined Dec 14, '06
From MN, USA
I got it done, but runs like crap. I'm thinking timing. First time it sounded kinda rough, bogging. Then shut it off. Second time it squealed like its the starter.
post Oct 30, 2007 - 2:48 PM
95CelicaST
Joined Feb 5, '05
make sure your belts are tight.
**** Photobucket
post Oct 30, 2007 - 4:58 PM
celicamike
Joined Dec 26, '05
From So Cal
you could also replace the oil pump and front crank seal, while you're in there.
Lo-Fi Version Time is now: November 25th, 2024 - 12:54 PM
