> lack of heat st202
post Nov 20, 2007 - 3:54 PM
lorrainess2
Joined May 28, '07
From eastbourne
iv`e got cold air blowing from the a/c but when the temps turned up the air is only luke warm.
i`ve done a search or 2 and been told there could be air in the system or the thermostat could be faulty
can anyone give me some detailed tips on how to flush the system out and start afresh and where the thermostat is again some details on removing this
cheers
Replies (1 - 15)
post Nov 20, 2007 - 7:01 PM
azian_advanced
Joined Apr 18, '05
From Calgary
there's a few threads on how to flush your radiator...
it's pretty simple. basically when you do it, be sure to have your hvac control dial set to hot and (if you can) jack up the rear of the car so it's inclined forward.. the drain plug is on the lower passenger side behind the radiator (a white plug) that comes off with a simple twist.
the thermostat is inside the metal neck part of the passenger-side radiator hose coming into the block. there's two bolts holding it down.. but to gain access to it, you'll need to remove the alternator and loosen/remove the AC compressor in order to reach the bottom of the two bolts (if you have AC).
after putting everything back together, make sure you bleed the system. i use a funnel (below) to bleed the system:
it basically ensures that coolant is always topped off..
post Nov 20, 2007 - 7:08 PM
azian_advanced
Joined Apr 18, '05
From Calgary
squeezing the radiator hose a few times also helps the bubbles escape, but make sure the car isn't jacked up in the back during the bleeding process.
don't forget to fill up the overflow bottle about a quarter to half way.. as it warms up, the coolant will expand and dump some in the overflow bottle.. take note, once the bottle is filled, it will come out from a little overflow hole at the top of the neck and (possibly) make a bit of a mess.
post Nov 21, 2007 - 1:26 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Check the black cable that goes from the climate control unit through the firewall to the heater control valve. Make sure it didn't come unclipped from its holder under the dash. If it did the valve will not open when the temperature control knob is moved and will prevent the heater core from getting warm.
post Nov 21, 2007 - 1:33 AM
azian_advanced
Joined Apr 18, '05
From Calgary
this is the cable WannabeGT4 is referring to, fyi:
post Nov 21, 2007 - 1:46 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Thanks Azian. I'm too lazy to post illustrations.
Celicam8
Joined Nov 17, '07
QUOTE(WannabeGT4 @ Nov 21, 2007 - 1:26 AM) [snapback]616188[/snapback]
he should check the blue one... thats the one that controls the heat
post Nov 21, 2007 - 1:48 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Blue controls the air mixer door. Black controls the heater core valve. Both should be checked actually.
post Nov 21, 2007 - 1:50 AM
Celicam8
Joined Nov 17, '07
agreed wannabe
post Nov 21, 2007 - 1:56 PM
CelicaST_CALI
Joined Feb 28, '07
QUOTE(azian_advanced @ Nov 20, 2007 - 4:01 PM) [snapback]616077[/snapback]
Azian u got one of these for the ST?id like the wiring diagram and what ever technical diagrams there are please,pm them to me plz.thanks,srry for the thread jack
BANNED. for life, you moron.
post Nov 23, 2007 - 12:52 PM
lorrainess2
Joined May 28, '07
From eastbourne
thanks for the helpfull replys guys, i`ll get my boyfriend to flush the radiator through at the weekend, but i`ll leave the thermostat to my mechanic
post Nov 23, 2007 - 2:46 PM
CelicaST_CALI
Joined Feb 28, '07
its not that hard^^^,drain the coolant,flush it out with water,add new coolant...
post Nov 23, 2007 - 3:03 PM
Celicam8
Joined Nov 17, '07
I remember reading here that someone here had the same problem, check your ground wire on the climate unit..
post Nov 23, 2007 - 5:16 PM
lorrainess2
Joined May 28, '07
From eastbourne
where would that be?
it`ll give him something to do tomorrow
post Nov 23, 2007 - 5:48 PM
Celicam8
Joined Nov 17, '07
http://www.6gc.net/forums/index.php?showtopic=53089
This post has been edited by Celicam8: Nov 23, 2007 - 5:48 PM
post Nov 23, 2007 - 6:40 PM
lorrainess2
Joined May 28, '07
From eastbourne
thanks once again
Lo-Fi Version Time is now: November 27th, 2024 - 4:03 AM
