Enthusiast ![]() ![]() ![]() Joined Jun 21, '07 From SoCal Currently Offline Reputation: 0 (0%) ![]() |
what happend to that article???????
its gone....and i need to install my alpine type r components i got **** someone help |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) ![]() |
what help do you need? do you have spacers for them?
![]() Enthusiast ![]() ![]() ![]() Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) ![]() |
I think 1 Question mark covers your need..
First you need spacers... HERE Then you need to remove the door panel... HERE Then you need this... HERE -------------------- |
Enthusiast ![]() ![]() Joined Apr 22, '07 From Buckinghamshire, UK Currently Offline Reputation: 2 (100%) ![]() |
here are some pics....
ummmm those pics dont help!! lol...no really
also yes i have spacers...it came with i need help how to install it after i remove the door panel... do i just replace it? |
QUOTE(mrgrape @ Nov 27, 2007 - 11:29 PM) [snapback]617468[/snapback] ummmm those pics dont help!! lol...no really also yes i have spacers...it came with i need help how to install it after i remove the door panel... do i just replace it? Right, you have 2 options. 1. Use OEM speaker cable through the door. 2. Use uprated OFC speaker cable, but that involves threading new wire through the door loom. Once you have decided one of the two options, you have another pair of options to choose from. 1. Mount the crossover network hidden behind the door card. 2. Mount the crossover network Outside the doorcard on display. If the crossover is mounted in the cabin, or boot, you will need 2 pairs of wire each side for tweets and mids. Now the work begins. 1. Remove old speakers and plastic holder. 2. Prise old speakers off the holder. 3. Fetch the spacers. 4. Mount new woofers onto spacers. (I fitted my MB Quart) woofer behind due to the angle of the basket, and to be honest I couldnt be arsed to file it as it was a ferfect fit behind, and it was about to rain (always rains in UK). 5. Connect the wire to the woofer, then screw the spacer with the woofer already mounted onto the door. The wire should be run through the little gap at the top between the plastic holder and spacer. 6. Now your woofer is screwed in, and wire dangling you can fit the crossover etc as you see fit, from the decisions you made about how you want it set up. Time: Once planned, about 30 minutes a side. Needed: Phillips screwdriver , Flat screwdriver, silicone sealant, precision screwdriver, soldering iron (for the prefectionists), crimp connectors. Hope this helps. Jay |
k took off the old speaker....but now do i keep the holder and attach the speaker to it????its too small and how do i take the wiring off of the old speaker???
![]() Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) ![]() |
pull the wires out of the speaker... put wires in new speaker...
-------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
do u mean cut it off....cuz i cant pull those wires.......
![]() Enthusiast ![]() Joined Jan 19, '07 From Indianapolis Currently Offline Reputation: 0 (0%) ![]() |
I'm not much help as far as install goes, as my dad helped me install my speakers, but I didn't need spacers, they just dropped right in where the OEM's came out. But I have a 94 ST Coupe, maybe the audio setup is different....
you sure about that?? there's no way the 6.5" can fit in the 8" which is on every US celica... unless they weren't factory speakers
QUOTE(mrgrape @ Nov 28, 2007 - 3:52 AM) [snapback]617577[/snapback] do u mean cut it off....cuz i cant pull those wires....... Right, there is a 2 pin connector for the speaker. You need to cut the wire where the connector is, then solder or crimp the new wire there for the speaker. Unless you have an 8 inch speaker, you WILL need a spacer. Jasopn. |
oh k....but now how do i fit the speaker inthe original plastic holder.....
like to me the speaker just fits straight through,..but isnt tight enough OMG GAY |
do you have the black spacer listed above?? thats what you need and then you just screw it in
yeah my Celica definitely doesn't have the spacer. And the speakers dropped in perfectly fine. I swear to god.
GAY AS ****
i took it to bestbuy for them to do it for $70 then theyre like 1 hour later....well need $80 more dollars for to install things to make the speaker hole fill in an 8' wtf???? what am i supposed to do now |
You make a thread for people to help you and you take it to best buy and waste your money?
No sympathy. -------------------- |
beyond belief!!
Enthusiast ![]() ![]() Joined Aug 22, '07 From Burnaby, British Columbia, Canada Currently Offline Reputation: 8 (100%) ![]() |
QUOTE(mrgrape @ Nov 28, 2007 - 2:41 AM) [snapback]617659[/snapback] oh k....but now how do i fit the speaker inthe original plastic holder..... like to me the speaker just fits straight through,..but isnt tight enough OMG GAY The reson it's not fitting is....(refer to FunkySR's post) QUOTE(FunkySR @ Nov 28, 2007 - 2:16 AM) [snapback]617652[/snapback] Right, there is a 2 pin connector for the speaker. You need to cut the wire where the connector is, then solder or crimp the new wire there for the speaker. Unless you have an 8 inch speaker, you WILL need a spacer. Jasopn. the "plastic holder" we have for our car fit's 8inch speakers...the speaker u got is a 6.5 inch if i remember reading correctly...so u have 1.5 inch gap..hence where the spacer comes into play...it fills that gap...it's like a 1.5 inch "large washer" u'd use w/ nuts and bolts.... wut best buy is doin is being gay and overcharging $80 you for most likely a piece of plastic that they probably have to trace and cut out and drill few holes... what i would do is complain...hopfully u didn't pay them 80 more..and say to quoted me 70 i'm not paying n e more..if u dun want to finish the job then put the speaker and panel back in and return my money...if that doesn't work..consider urself... ![]() This post has been edited by nammer: Dec 6, 2007 - 5:03 AM -------------------- |
the spacers dont even fit the 8'...thats why like the bestbuy ppl are like yeah its going to cost $80 more dollars to have us install like pillow stuff that surrounds the speaker
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:38 PM |
