Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) ![]() |
Trying to diagnose my problem and I can't seem to figure it out. My car won't reach its operating temperature unless I got it opened up on the highway. As soon as I slow down the temperature drops. Any suggestions?
start with the thermostat, replace it.
QUOTE(Bitter @ Dec 15, 2007 - 9:52 AM) [snapback]622982[/snapback] start with the thermostat, replace it. that was my first thought, that it was a failsafe and it was stuck open. But i changed it and still the same problem. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
Real Cold weather in combination with you using the heater core at maximum temp and highest fan speed?
-------------------- JDM Powerplant installed, BPU coming very soon!
QUOTE(Kadett @ Dec 15, 2007 - 1:00 PM) [snapback]622992[/snapback] Real Cold weather in combination with you using the heater core at maximum temp and highest fan speed? eh, i can blast the heat in my 7afe when the outside temp is 20F and im traveling at 30mph and not get a dip on the temp gauge. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
does your heater provide good heat? if not, there's the possibility of having air in the cooling system, it takes a bit of time to warm up completely if you're trying to bleed it in these cold temperatures.. otherwise maybe it's just a bad thermistor water sensor...
try replacing the temp sensor for the gauge.
QUOTE(azian_advanced @ Dec 15, 2007 - 3:59 PM) [snapback]623051[/snapback] does your heater provide good heat? if not, there's the possibility of having air in the cooling system, it takes a bit of time to warm up completely if you're trying to bleed it in these cold temperatures.. otherwise maybe it's just a bad thermistor water sensor... Air in the system will cause it to over heat QUOTE(lagos @ Dec 16, 2007 - 12:01 AM) [snapback]623135[/snapback] try replacing the temp sensor for the gauge. If it was the temp sensor, the car would still heat up and blow heat. |
Enthusiast ![]() ![]() Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) ![]() |
QUOTE(lagos @ Dec 16, 2007 - 2:01 AM) [snapback]623135[/snapback] try replacing the temp sensor for the gauge. X2 -------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) ![]() |
Gonna go with its cold as **** out. Mine is the same way, its cold as hell and wind breeze at driving speed doesn't help either. My temp gauge sits just below 1/3 line.
Only thing you can really do is change your oil to something suitable for winter temps. A stock motor will never see the temps in the winter that it sees in the summer. Your radiator is going to cool your motor alot more with 10*F then it would in 90*F. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
Radiator flush and new coolant, there just may be a clog. If that doesn't work, I'd try the air temp sensor, it's about 20 bucks and an inexpensive process of elimination. Also make sure you didn't get a faulty thermostat, they're cheap little buggers and it's possible you inadvertently got the wrong one or a faulty one.
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:32 AM |
