> HELP! Swapping a 20V ST to a 97 Corolla CE: HELP!!!
post Dec 24, 2007 - 11:23 AM
jdg371
Joined Jun 14, '05
I have a friend that wants to swap out a 4afe to a 4age 20v st. needs a new ecu and probaly new engine mounts. anything else i need for the swap and any links rthat i should check out for these things.
Replies (1 - 1)
post Dec 24, 2007 - 12:33 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
He'll need a 20V ECU and harness. It will drop in to his motor mounts and current transmission, as they are both A series motors.
I don't know if everything is similar to the Celica swap, but he might need a new throttle cable off of a Paseo, and depending on where the power steering res is located on the Corolla he'll need the entire 20V power steering setup.
**** Photobucket
Lo-Fi Version Time is now: April 29th, 2025 - 5:39 PM
