![]() Enthusiast ![]() Joined Mar 4, '07 From Poughkeepsie, NY Currently Offline Reputation: 0 (0%) ![]() |
SOOOO my car is shaking when I accelerate around 67mph. But as soon as it hits 70 it completly stops. It doesn't matter if I'm going up hill or not but has anyone ever heard of this happening? Also I looked at the rpm's last time it was happening and it was barely over the 2 so its not really high or anything.
![]() Enthusiast ![]() ![]() ![]() Joined Apr 12, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
Possibly an issue with the power steering system. This is more of an estimation considering our cars have variable assisted power steering and at 70 I believe the power steering almost completely stops assisting.
-------------------- "He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn." "What?" "Just do it." ".......He said yes." "Tell him you are not darklings. He should open up." ".......Sweet. Thanks." "No problem." |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 21, '07 From Toronto Currently Offline Reputation: 1 (100%) ![]() |
check alignment...
-------------------- -Derick
![]() "In hoc signo vinces." In this sign thou shalt conquer." Gone but never forgotten.... |
Enthusiast ![]() ![]() Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) ![]() |
i agree with Jeunesse tht happen to me when i put my new rims and tires without getting an aligment.the car started shaking aroud 75.
Enthusiast ![]() ![]() ![]() Joined Jun 21, '07 From SoCal Currently Offline Reputation: 0 (0%) ![]() |
mine shakes around 90!!!!
QUOTE(mrgrape @ Dec 27, 2007 - 12:49 PM) [snapback]626032[/snapback] mine shakes around 90!!!! for some reason I thing there will be a tragic post related to this. -------------------- ![]() |
lol.. just check your wheel alignment... mine stop shaking when I did the alignment. It used to shake when I get to 80kmh then stops at 130kmh.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) ![]() |
hahaha go stevenson
if its shaking and on and off id presume it may be something with wheel balance, possibly hit a pot hole, knocked a weight off or something to that effect may ahve caused it, alignment to my understanding would cause shaking as a specific speed interval like that, more so a wheel balance issue. try that first as its usually alot cheaper than a full alignment (think balance is like $20 around here and an alignment is like $80) and unless your smakin some curbs pretty hard your alignment shouldn't be messed up, and if it is adjust your driving (but as i remember your the cool one who threw your wallet into coreys car dwg) if its not your wheels then may be your trans having some type of shifting issue if its only at those speeds relevent on how much accelerating, if it does it no matter what at those speeds im gonna go with balance -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
![]() ![]() ![]() ![]() (2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
QUOTE(jason @ Dec 27, 2007 - 8:47 PM) [snapback]626082[/snapback] hahaha go stevenson if its shaking and on and off id presume it may be something with wheel balance, possibly hit a pot hole, knocked a weight off or something to that effect may ahve caused it, alignment to my understanding would cause shaking as a specific speed interval like that, more so a wheel balance issue. try that first as its usually alot cheaper than a full alignment (think balance is like $20 around here and an alignment is like $80) and unless your smakin some curbs pretty hard your alignment shouldn't be messed up, and if it is adjust your driving (but as i remember your the cool one who threw your wallet into coreys car dwg) if its not your wheels then may be your trans having some type of shifting issue if its only at those speeds relevent on how much accelerating, if it does it no matter what at those speeds im gonna go with balance Now that you mention it, I think it could be the alignment. I hit a curb real bad a while back and shaved off part of the rim and about a month ago I went over a curb. When you are parking and you are the closest spot and you go to back up out of the spot but you don't back up enough, Yeah, thats what I seem to do. |
![]() Enthusiast ![]() ![]() Joined Nov 4, '03 From Colorful Colorado Currently Offline Reputation: 13 (100%) ![]() |
It could be the tire balance, if your tires are out of balance it will cause a bad vibration in the car at surtain speeds but smooth out when accelerated
-------------------- 1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
1995 Toyota Celica Coupe GT 3S-GTE 1994 Toyota Celica Liftback GT-Four (RHD/GT-Four conversion) 1990 Toyota Xcab 1UZ-FE Lexus V8, Solid Axle Swap on 35s geared and locked dual Tcases (Rock Crawler) 1990 Toyota 4Runner 5VZ-FE V6 swap, Solid Axle Swap on 38s (Rock Crawler) 1972 Ford F-350 Crew Cab 4X4 Cummins Turbo Diesel (Tow Rig) 1956 Ford F-100 429 / Automatic 1969 Ford Mustang Fastback 429 Tubbed and Caged (Drag Car) 1967 Ford Mustang Fastback 427W / Automatic 1965 Ford Mustang Fastback 347 / 5-speed |
![]() Enthusiast ![]() Joined May 29, '07 From Trondheim/Norway Currently Offline Reputation: 1 (100%) ![]() |
You could also check your brake-discs... they may have been broken due to hot disc, hitting cold water...
This post has been edited by peterkos: Dec 28, 2007 - 5:36 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
shaking at certain mph is wheel balance or possible bent rim (which would cause it to be out of balance).
pulling to one side or steering wheel not straight is alignment. shaking while braking is rotors out of round. pulling to one side while braking is possible frozen caliper. This post has been edited by hurley97: Dec 28, 2007 - 7:22 PM -------------------- |
^ listen to this woman
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
Could also be axels? i know mine need replacing, and my car recently begins shaking at around 60 but stops around 70. idk look under there check you boots and get wheels balanced first
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
hahah you guys up there drive fast...........honestly the fastest i drove was 65mph..........on the freeway...........town/city driving.......25-35-45 depends..........lol
maybe you shouldnt drive as fast HAHAHAH just jokes -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
![]() Enthusiast ![]() ![]() ![]() Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) ![]() |
Had the same issue from 70-72 only. My rear wheels were not balanced properly and it fixed the issue. I knew it had to the be rears as I had the fronts balanced when I took a nail in the driver side.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) ![]() |
call car talk...
QUOTE(Harold_Fastwaker @ Dec 31, 2007 - 3:51 AM) [snapback]626903[/snapback] Had the same issue from 70-72 only. My rear wheels were not balanced properly and it fixed the issue. I knew it had to the be rears as I had the fronts balanced when I took a nail in the driver side. rear wheels you will feel the whole car shake fronts will make the steering wheel shake -------------------- |
I will have to get the wheels checked...balance that is...I just got back from vacation but luckily I still have a week left before I start school once again
Lo-Fi Version | Time is now: February 19th, 2025 - 12:31 AM |
