7AFTE TURBO SETUP |
7AFTE TURBO SETUP |
Jan 22, 2008 - 12:12 AM |
Enthusiast Joined Jan 31, '07 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
Anyone with a 7afte please ans if this setup is good or anthing needs to be changed: Can i run around 12psi with this setup?
- T3 turbo - Custom down pipe - Jgs tools manifold - Turboxs manual boost control - Short ram intake and filter - Vortech 12:1 Fuel management unit with fuel lines - Walbro 255lph supra fuel pump - Lime green top Supra 315cc Fuel injectors - Jgs tools oil feed line kit - Custom oil return line - Pre tapped and fitted oil pan - Greddy universal Intercooler piping kit - Front mounted intercooler - Monza SSQV Blow off valve - Air lines - Check valves for the MAP - SAFC2 - Triple gauge pod - Oil Pressure Gauge - Boost Gauge - Voltmeter Gauge - NGK V-Power grade 8 spark plugs - Stage 2 clutch thanks for any help... This post has been edited by mikecelica: Jan 22, 2008 - 10:54 AM |
Jan 22, 2008 - 2:42 AM |
Enthusiast Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
Well, that was the original 7a build from Nik. Now everyone has decided to go without check valves and FMUs and opted for an actual build. Which requires larger High Imp injectors (310cc or larger) a 2 bar map sensor (either from GM or most of us use a 3sgte map sensor.
For tuning, you can use the SAFC, an Apexi Neo works as well. If you want to go farther you can use a Greddy Emanage. However for the Emanage you need the full kit, the E- Blue does not have many tuning options. As for 12 psi, that depends on what trim t3 you are running. This post has been edited by Harold_Fastwaker: Jan 22, 2008 - 2:43 AM -------------------- |
Jan 22, 2008 - 10:57 AM |
what if i use larger injectors but still the check valves and fmu, with the safc2. think i woulkd be ok or is it still better to just get the 3s map sensor?
Jan 22, 2008 - 2:16 PM |
QUOTE(mikecelica @ Jan 22, 2008 - 12:57 PM) [snapback]633220[/snapback] what if i use larger injectors but still the check valves and fmu, with the safc2. think i woulkd be ok or is it still better to just get the 3s map sensor? I will answer your other question as well for what other injectors to look at. RC engineering makes great injectors. I would honestly shoot for buying something thats 350cc or 360cc. The 315s are fine, but you can not push past 200hp with them. If you do buy used injectors, please send them off for flow testing and a good cleaning. RC engineering also does this for people, I believe it was $15 per injector. Now, if you are looking to spend the money for injectors I would not skimp on the check valves. That was Niks first way of fooling the motor. Now we have a much better/reliable way of doing it. The 3s map sensor is just about $70-$80 used from MR2OC. -------------------- |
Jan 22, 2008 - 3:01 PM |
yeah but what im confused about is why we need a 2bar map sensor,isnt our stock map sensor able to read 1bar? so 15psi is more then enough for me.
Jan 22, 2008 - 3:33 PM |
QUOTE(mikecelica @ Jan 22, 2008 - 3:01 PM) [snapback]633292[/snapback] yeah but what im confused about is why we need a 2bar map sensor,isnt our stock map sensor able to read 1bar? so 15psi is more then enough for me. It can only read Vac to 1bar of atmosphere (0psi). You need a 2 bar map to read boost up 15psi. This post has been edited by lagos: Jan 22, 2008 - 3:35 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 22, 2008 - 3:38 PM |
Enthusiast Joined Dec 11, '07 From Norway Currently Offline Reputation: 0 (0%) |
QUOTE(mikecelica @ Jan 22, 2008 - 3:01 PM) [snapback]633292[/snapback] yeah but what im confused about is why we need a 2bar map sensor,isnt our stock map sensor able to read 1bar? so 15psi is more then enough for me. You could go with e-manage and get the greddy boost sensor for it. You'll also get to controll the injectors and the fuel cut with it. |
Jan 22, 2008 - 3:45 PM |
okk that makes alot of sense now, but i was also wondering if its just opinion or is it better to upgrade to a 2 bar map sensor then just use check valves?
This post has been edited by mikecelica: Jan 22, 2008 - 6:39 PM |
Jan 22, 2008 - 9:06 PM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
go with proper built. get a 2bar map sensor. I dun think the map sensor that costly
Jan 23, 2008 - 12:31 AM |
QUOTE(mikecelica @ Jan 22, 2008 - 5:45 PM) [snapback]633308[/snapback] okk that makes alot of sense now, but i was also wondering if its just opinion or is it better to upgrade to a 2 bar map sensor then just use check valves? Its not an opinion. It is a statement. upgrade to a 2 bar -------------------- |
Jan 23, 2008 - 11:49 PM |
are the 2 bar map sensors off GM direct plug in too or only the turbo mr2 ones?
Jan 27, 2008 - 10:09 PM |
what are the best spark plugs to use with a turbo 7afe?
Jan 31, 2008 - 8:14 AM |
Run on stock head gasket?
Jan 31, 2008 - 11:31 AM |
yes
Jan 31, 2008 - 6:33 PM |
some ppl are saying to get a thicker one to lower compression and others say u will lose power doing this so im confused as to what to do...?
Jan 31, 2008 - 9:11 PM |
im sure u will run into same problem like pabel89. you don't really know what you doing. yo're merely buying by using other plp list.
Jan 31, 2008 - 10:01 PM |
Enthusiast Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) |
QUOTE(normality78 @ Jan 31, 2008 - 9:11 PM) [snapback]636683[/snapback] im sure u will run into same problem like pabel89. you don't really know what you doing. yo're merely buying by using other plp list. i might not of known what i was doing, but i still finish my 7afte and tht fuel choking thing, was just one of my injector harness wasnt sending any volts.now im running 10psi daily with no problem |
Feb 1, 2008 - 4:54 AM |
I blew my headgasket on 14 psi boost, but I think it was in bad shape from before.
I have been searching for a upgraded one for 7a-fe and it looks like the one to use would come from a 4a-zge (think it was that, dont have my notes atm) Greddy EM is also recomended so you can adjust fuel cut and ignition. Still cant get the ignition to work but everything is ok. Gonna make a howto as soon as I figure out the ignition wire. @Pebel89: could you look at your ignition wire harness setup? Should be 2 wire's on plug number 2 on the EM blue. This post has been edited by Turbofun: Feb 1, 2008 - 4:57 AM |
Feb 3, 2008 - 11:43 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
wtf are "air lines"????
Lo-Fi Version | Time is now: November 27th, 2024 - 11:45 PM |
