> drilled/slotted rotors, installing
post Jan 24, 2008 - 2:18 PM
hongkongnerdboy
Joined Jul 26, '07
From riverside,CA
have any of you installed it yourself?
Replies (1 - 11)
post Jan 24, 2008 - 2:59 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
since i have tools to do it, its easy.
This post has been edited by LewFX: Jan 24, 2008 - 3:00 PM
post Jan 24, 2008 - 3:57 PM
hongkongnerdboy
Joined Jul 26, '07
From riverside,CA
post Jan 24, 2008 - 8:42 PM
http://www.6gc.net/forums/index.php?showtopic=45518
post Jan 24, 2008 - 11:51 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
I need to do this as well =/
post Jan 25, 2008 - 1:36 AM
creis
Joined Jan 10, '04
From Shoreline, WA
rotors are a very easy install, pretty much just take the tire off and swing the calipar up, the old onces should just pound off, just gata be careful and take your time as your cars breaks are extreamly important when it comes to stopping smile.gif I've put brimbo drilled rotors on my celica and my subaru, with ceramic pads, I consider it one of the few "money well spent" upgrades weither you race or not.
post Jan 25, 2008 - 12:29 PM
LewFX
Joined Jan 28, '05
QUOTE(hongkongnerdboy @ Jan 24, 2008 - 2:57 PM) [snapback]634119[/snapback]
charge you only 20 bucks to do it
post Jan 26, 2008 - 6:57 AM
draysniro
Joined Jan 19, '08
From PA
QUOTE(creis @ Jan 25, 2008 - 1:36 AM) [snapback]634314[/snapback]
Where'd you get the Brembo kit? I've been looking but all I can find is for the 00+. Did you do the front and rear? I'm wanting to upgrade sometime soon.
post Jan 28, 2008 - 8:48 AM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
did it this weekend for the 2nd time ever , easy. first time the how to helped tons
post Jan 29, 2008 - 12:06 AM
CelicaST_CALI
Joined Feb 28, '07
QUOTE(LewFX @ Jan 25, 2008 - 9:29 AM) [snapback]634398[/snapback]
BANNED. for life, you moron.
post Jan 29, 2008 - 1:40 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
really easy did it in a couple hours by myself. needless to say i was quite pleased with myself.a
post Jan 29, 2008 - 6:33 AM
SteveHall
Joined Nov 8, '07
From Surrey, England
When I changed my discs I had to buy one of these:
IPB Image (It's an Irwin bolt grip)
As the previous owner / mechanic rounded off the caliper bolts.
When reinstalling calipers you should use some loctite 243 on the caplier to car bolts, and possibly others if you've broken their seal, I took my calipers off in a different way to the how to as I wasn't changing pads. Quote from Loctite:
"LOCTITE® 243™ is designed for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools. The product cures when confined in the absence of air between close fitting metal surfaces and prevents loosening and leakage from shock and vibration. Particularly suitable for applications on less active substrates such as stainless steel and plated surfaces, where disassembly with hand tools is required for servicing. The thixotropic nature of LOCTITE® 243™ reduces the migration of liquid product after application to the substrate."
This post has been edited by SteveHall: Jan 29, 2008 - 6:36 AM
Lo-Fi Version Time is now: February 22nd, 2025 - 5:54 AM
