15mpg on my ST wtf? |
Feb 5, 2008 - 12:00 AM |
Enthusiast Joined Jan 31, '07 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
i recently was tryna do my gauges and broke the pointer for the gas gauge and the little ACTUAL NEEDLE that is inside a lil motor which controls the fuel gauge. anways i couldnt fix it and now my gauge is broken but after about 300km = 190miles , the gas light comes on. so do the actual needle and whatver controls the gas light work together as in if one gets messed up so is the other or no. cuz it cant be possible im gettin half the fuel economy i shud be getting. my car is pretty stock, i checked gas tank and lines no leak anywhere..??? THANKS FOR ANY HELP.
Feb 5, 2008 - 1:10 AM |
anyone know?
Feb 5, 2008 - 8:40 AM |
Enthusiast Joined Jul 11, '06 From Sefner, FL Currently Offline Reputation: 24 (100%) |
the guage jsut reads an electrical signal it doesnt actually control the fuel consumption im pretty sure off. ive never heard of an st loosing that much mileage, i would seriously suggest taking it to a shop to run an eng code check and see if any error codes come up. Also make sure they check the fuel system, fuel pump, fuel filter injectors etc
Feb 5, 2008 - 9:59 AM |
Enthusiast Joined Jul 7, '04 From Germantown, WI Currently Offline Reputation: 0 (0%) |
If you really want to check your gas mileage just fill up until the nozzle auto shuts off, take note of the station and pump you used, reset your trip odometer, and drive for a few days. Then fill up at the same pump until it auto shuts off and then divide the distance on your trip odo by the liters you pumped. You don't need a gas gauge to determine gas mileage.
Feb 5, 2008 - 3:02 PM |
Enthusiast Joined Feb 4, '08 From Brunswick, Ohio Currently Offline Reputation: 0 (0%) |
jw..how many gallons can a 94 st coupe hold?
Feb 5, 2008 - 4:00 PM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
bad o2 sensor.
about 50 something litres = 11 gallons
Feb 5, 2008 - 4:06 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
i think an st holds more to 14.5 15 gallons.
my fuel light comes on a 1/4 tank left... and that gives me another 120 or so miles. never ran outta fuel. i just note the trip milage when the light comes on, add 100, and get gas when it gets there seems like something may be setting your gas light on sooner than it should be -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Feb 5, 2008 - 4:14 PM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
its 15.9 for a GT....well close to that. im sure the st isnt too far off
Feb 5, 2008 - 4:57 PM |
QUOTE(red94celicast @ Feb 5, 2008 - 3:02 PM) [snapback]638349[/snapback] jw..how many gallons can a 94 st coupe hold? QUOTE(mneal2_92788 @ Feb 5, 2008 - 4:14 PM) [snapback]638378[/snapback] its 15.9 for a GT....well close to that. im sure the st isnt too far off correct. It's actually 60 liters (15.85 gallons) for ST and GT, same tanks. no dount you have a bad 02 sensor. -------------------- |
Feb 5, 2008 - 6:18 PM |
Enthusiast Joined Jan 15, '08 From Secaucus NJ Currently Offline Reputation: 0 (0%) |
Mine fills up at like 12.3 or sumthing
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:56 AM |
