noise from drivers side back tire |
Feb 10, 2008 - 8:42 PM |
Enthusiast Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) |
sounds like the brakes are lightly scraping the disks cant hear when going fast since wind noise but when you hvae the window down and going pretty slow you can hear it a bit,
do i need to just take out the brake pad and put it on again? i dont now any help please -------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
Feb 10, 2008 - 9:13 PM |
Enthusiast Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
Well your topic headline says "drivers side back" but the post alludes to both.... i would try taking them both out and adjusting them, checkin to see how much wear is on them...... if both of em are making the noise constantly, check out your e-brake setting...... if all of that is fine, it rules out your brakes
Feb 10, 2008 - 9:14 PM |
well my bad for putting an s at the end
Feb 10, 2008 - 9:26 PM |
Yeah, I'd check out the brakes and take em out and reinstall em and make sure they are adjusted properly...... if that doesn't take care of it, see if you can see anything that looks like it may be rubbing back there
Feb 10, 2008 - 9:41 PM |
alrightyyy thanks
Feb 10, 2008 - 10:04 PM |
there should be a pin that sticks along side your pads. if it touchs the rotor it will make noises. that's a sign that you need new pads. that or you can just take them out. but check on the pin. and blast the rotor and pads with brake cleaner.
Feb 11, 2008 - 11:32 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Also be sure you have the triangle shaped return springs still attached - this could caus what you're hearing and is pretty common to be missing.
-------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Feb 12, 2008 - 9:58 AM |
Enthusiast Joined Nov 8, '07 From Surrey, England Currently Offline Reputation: 0 (0%) |
This may sound stupid, but check your wheel nuts are done up tight. I had this once after I changed the discs, loose nuts = loose disc = rubbing on pad.
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:53 PM |
