turbo help asap, would this fit |
Aug 26, 2003 - 4:19 PM |
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2428836113 its a supra turbo but would the flange bolt onto a 3sgte manifold. everyhting else should work right?
Aug 26, 2003 - 5:47 PM |
Enthusiast Joined Sep 13, '02 From BC, Canada Currently Offline Reputation: 0 (0%) |
i'm not an expert by any means on this subject, but isn't the CT26 turbo the one that comes stock on the 3sgte? and doesn't the supra come with a twin turbo or something? i'm not sure if i trust what this guy is saying, his english is kind of shotty and it's a little weird that he wanted to keep the turbo for so long without selling it sooner...
but like i said before, you should get another opinion as well as mine |
Aug 26, 2003 - 6:14 PM |
Enthusiast Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
yes, that is the ct-26 turbo, it will bolt up to a 3s-gte turbo manifold, which will bolt up to your 5s-fe block.
feel free to read the thread on turbocharging your 5s-fe. -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Aug 26, 2003 - 7:01 PM |
i have read ur thread dam it slipped my mind. very good thred by the way. thx
Aug 27, 2003 - 4:23 AM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Make sure you read the part about the turbo's...... You reminded me about it .
-Bryan- -------------------- Member of Team 5sfTe
Aug 27, 2003 - 4:35 AM |
Enthusiast Joined Mar 4, '03 Currently Offline Reputation: 0 (0%) |
I would say if you get it for a bargain you might as well, because you have a lot of options on getting work done on it.
Unless there is a major problem with it, you will be able to get it reconditioned (if not upgraded) fairly cheaply if you shop around. |
Aug 27, 2003 - 5:04 AM |
It looks clean and all but the pics are a bit ruff and there are no shots of the impellers. I would not buy a turbo from ebay. Go on the mr2 boards and get one from them. You can get a low milage one from a swap for around 200 or so.
Aug 27, 2003 - 11:07 AM |
i read one turbo add on ebay and it said. two fns are slightly bent but not enuf to affect perfomance. is this true... cuz i told my dad i liked this turbo and he boght it without me even knowing.... so chek it ous. hopefully it works. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2429133167
Aug 27, 2003 - 1:47 PM |
Well I would take the turbo to a shop to be checked out. Even if you need to rebuild it you made out by getting all the oil and coolent lines with it.
Aug 27, 2003 - 9:26 PM |
what type of shop will do turbo's? also its cheaper to repair a turbo than buy a new one right?...
Aug 27, 2003 - 9:42 PM |
well, you just kinda half to look around for a local speed shop, and as far as the cost goes, I've found that its sometimes cheaper to buy a new turbo.
but that allways depends and who you buy from, or who repairs your turbo -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Aug 27, 2003 - 10:40 PM |
whats a safe psi to run.
Aug 28, 2003 - 8:50 AM |
Enthusiast Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
Hope it all works out for ya, kepe us posted. Im just glad u didnt buy that one from the guy with the shotty english.
Aug 28, 2003 - 12:42 PM |
on the 5s-fe I would never recommend boosting higher than 8 psi unless you sre intercooled, this kind of pressure really puts a strain on your connecting rods.
the reason I say no more than 8 unless intercooled is because if you have an intercooler to cool the air in your intake the result will be colder denser air, so if you run 11 or 12 psi intercooled, the mass that the air takes up is less. also, you will need larger fuel injectors for this kind of boost, something like 360cc, couple these injectors with a supra fuel pump or a nice walbro. but, as far as having a reliable motor, I would run only like 5 pounds of boost. keep in mind the intercooler, while many kits do not comewith one, its great to have, the cooler the air, the more dense the air is, the more air is cramed into the combustion chamber, the more power you get so, at like 5 psi you may make about 9 hp for each psi, with an intercooler it might be a little more -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Aug 28, 2003 - 7:54 PM |
Enthusiast Joined Oct 27, '02 From Barbados Currently Offline Reputation: 0 (0%) |
Hi! There are some conflicting statements above. Review on air mass and dense air. Why no no to high boost? >>>Greater heat generated when compress, and more strain on the piston and crank and con. rod when compressing the air. As always, fuel delivery, head design, carbon built up and many other factors can contribute to pinging since the temp. of the intake air is alot higher. Also remember that the speed of the compressor wheel also contribute to the temp. as it compress the air. Either way, just an update -------------------- West_Minist
Hydra EMS Dealer & Tuner Subaru ECUFlash Tuner http://www.socob.bb http://xtremeracingtuning.com Viciously Tuned, Driven Hard |
Sep 5, 2003 - 10:47 PM |
alright i bought a ct 26 turbo. i think its a its first genneration one. so this header would fit that turbo...? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2431421812 check out how the flange is circular.
thats what my flange on my turbo looks like. soooo any thawts? -------------------- |
Sep 6, 2003 - 1:52 AM |
Yup that sure is thee one you want, make sure it has no cracks first tho.
Lo-Fi Version | Time is now: December 1st, 2024 - 5:47 PM |
