cel code 43 |
cel code 43 |
Mar 9, 2008 - 3:59 PM |
Enthusiast Joined Jan 25, '08 From Topeka, KS Currently Offline Reputation: 0 (0%) |
i'll just get to the point on this one. my CEL is on and when i cheked it, the code was 43.
code 43: "No STA signal to ECU until engine speed reaches 800 rpm with vehicle not moving." what exactly does this mean? i've searched for over half an hour and it still isn't making sense. Thank you. -------------------- 1st car- 1994 Celica GT 2.2L 5s-fe SOLD
2nd car- 1995 Celica ST 2.0L 3s-gte SOLD Current car- 1996 Z28 Camaro 5.7L LT1 |
Mar 9, 2008 - 7:38 PM |
Enthusiast Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
i dont know if i'm telling you anything new, but its your starter signal.
and dont think im trying to be an internet mechanic lol i just searched around too man. i read to check your ignition circuit switch. its like the engine isn't gettting the signal to turn over because its not cranking 800RPMS on start. thats just my take i could be wrong. hope this is somewhat helpful and good luck bro -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- |
Mar 9, 2008 - 8:03 PM |
yeah, thats what i read too. but when i started it, it starts just fine. its when i tap on the gas pedal while its idling, thats when the light comes on. thats what threw me off.
Mar 9, 2008 - 9:43 PM |
Enthusiast Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
The starter relay has a splice that connects to the ECU.
Whenever you try to start the car you send battery voltage to the starter through the starter relay. This means you also send battery voltage to the ECU on the STA input wire. If you're getting that code and the engine starting either that splice, the wire off the splice, the connection to the ECU or the ECU is bad. -------------------- |
Lo-Fi Version | Time is now: December 4th, 2024 - 4:29 AM |
