Headlight Lens removal help please!, how?? |
Mar 13, 2008 - 12:39 PM |
Enthusiast Joined Feb 20, '08 From Abingdon, Maryland Currently Offline Reputation: 7 (100%) |
is it possible to remove the lens from the brightlights without totaly destroying the lens? Cause I got brights, one with a bad lens and one with a bad casing, i just wana take the lens off one and switch it onto the other one. I tried practicing removing it on the lens that was already broken, but i couldn't do it without cracking the lens even more. I don't want to mess up on the good lens,
is this possible or am I just going after a lost cause? help anyone? |
Mar 13, 2008 - 2:12 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Pop the entire headlight assembly into the oven. Keep checking it. Once the black rubber stuff starts getting soft, take out the headlight and use a putty knife and pry it off at different points.
Mar 13, 2008 - 2:29 PM |
thanks, ill have to try that
any certian degree or time that anyone has done from past experiences? |
Mar 13, 2008 - 2:43 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
I have used 2 different methods before.
Stovetop Directions: I used a large pot of water and heated it to a boil. You do not need a lot of water as the highbeam will take up space in the pot and the water will surround it. Hardest part is finding a big enough pot. For the oven: I preheated the oven to 350 degrees for 15 minutes. I placed the highbeam on a 12x16 cookie sheet and placed it in the oven for a 30 seconds at first. Removed it and checked the condition of the glue. Put it back in the oven and made judgement from there (or until golden brown jk). Just keep an eye on it. When it is heated thoroughly, remove it from the oven and place it on a counter top or table. Slowly peel back lense (careful it's hot) and enjoy. -------------------- |
Mar 13, 2008 - 2:53 PM |
the oven way can warp or melt the housing and that's bad.
easiest and safest IMO boil water, insert high/low beam wait 5 minutes then pry glass from housing (remove clips) takes about 5-10 minutes. To replace glass, use a silicone glue and put the clips back on to hold it tight while it dries. -------------------- |
Mar 13, 2008 - 3:37 PM |
how much salt do you use.
does it work for all headlights the same? Is there a way to polish the glass -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Mar 13, 2008 - 4:49 PM |
Also, I'm guessing it's important to let your headlight come up to room temperature if you live anywhere cold, as putting cold glass in hot water will crack the glass.
x2 on the polishing of the lenses, where does one have this done? And how much does that cost? -------------------- |
Mar 13, 2008 - 6:27 PM |
well i did the lights
the oven trick worked like a charm, put em in boiling water for afew mins and presto! now i just need to finish getting all the water out of my back lights... |
Mar 13, 2008 - 7:34 PM |
QUOTE(Rymaster @ Mar 13, 2008 - 7:27 PM) [snapback]653460[/snapback] well i did the lights the oven trick worked like a charm, put em in boiling water for afew mins and presto! now i just need to finish getting all the water out of my back lights... are you painting them? the insides, so they look smoked? -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Mar 13, 2008 - 7:52 PM |
Enthusiast Joined Feb 21, '08 From Saint John, NB Currently Offline Reputation: 0 (0%) |
will this work the same with the tails? cause my passengers side is filled up half way with water lol and all my light sockets are correded (however u spell that word)
-------------------- 94 Celica GT Hatchback 5spd
89 Nissan 240sx coupe 5spd -RIP 87 BMW 325 2dr 5spd - SOLD- Gone but never forgotten |
Mar 13, 2008 - 8:10 PM |
QUOTE(tigersvain @ Mar 13, 2008 - 8:52 PM) [snapback]653508[/snapback] will this work the same with the tails? cause my passengers side is filled up half way with water lol and all my light sockets are correded (however u spell that word) i dont see why not, if u dare try it let us know.. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Mar 13, 2008 - 11:39 PM |
QUOTE(njccmd2002 @ Mar 13, 2008 - 7:34 PM) [snapback]653498[/snapback] are you painting them? the insides, so they look smoked? no, i just had to switch one light with a bad lens with another light with a bad casing. gave them a good cleaning, but no painting, QUOTE(tigersvain @ Mar 13, 2008 - 7:52 PM) [snapback]653508[/snapback] will this work the same with the tails? cause my passengers side is filled up half way with water lol and all my light sockets are correded (however u spell that word) umm, actually i had the same problem with my right tail light. I just took it off afew hours ago and drained it (was like half full, lol) I'm not sure if it will work the same..... at the moment i just have it cleaned out and sitting in my room to dry out |
Mar 16, 2008 - 1:55 PM |
Enthusiast Joined Sep 13, '07 From upstate ny Currently Offline Reputation: 1 (100%) |
wish i woulda asked this same question. i used a baseball bat lol
Lo-Fi Version | Time is now: December 3rd, 2024 - 10:48 AM |
