Where is this grease from? |
Mar 23, 2008 - 7:23 PM |
Enthusiast Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
Was looking under the car today, and noticed my front pass wheel was splattered with what appeared to be mud. Upon further inspection it turned out to be grease of some sort (petroleum based smell).
Mar 23, 2008 - 7:27 PM |
That would be your axle.
Get a new one or change the boot. Just dont ignore the problem or you'll be stuck calling a tow truck soon. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 23, 2008 - 7:42 PM |
Change those CV Boots as soon as you can or you'll be screwed by damaging the axles.
Mar 23, 2008 - 7:47 PM |
Enthusiast Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
yeah. your gonna have to replace those boots soon or you'll have get a new half shaft. unless when you turn slowly you hear clicking, then it may be too late..
Mar 23, 2008 - 7:53 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
no need for any KY...just reach under and grab a handful.
Mar 23, 2008 - 8:10 PM |
Enthusiast Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
Before you replace the boot, check the outer clamp [if there's even a clamp on there].
It looks like the grease is coming from there and not a split boot. -------------------- |
Mar 23, 2008 - 8:21 PM |
yeah. just feel around that first valley and see if there isn't a hole/rip.
Mar 23, 2008 - 8:49 PM |
I had a quick feel around the boot, but didn't wipe anything off yet to show where it was coming from. The boot seemed to be intact and not split anywhere, but I will wipe the grase off and double check. Where should the clamp be?
How would this have happened? I washed the car just before I put it away (and I spray out the inside of the wheels) so it must have happened on the way home from the car wash... |
Mar 23, 2008 - 8:52 PM |
it just happens.. i have a 94 i had to replace both when i bought. and another 94 that they were never replaced..
Mar 23, 2008 - 9:00 PM |
I'm aware things break down over time, but it seems odd that it happened on its final drive before it got parked for the cold...
Mar 23, 2008 - 9:11 PM |
Enthusiast Joined Nov 6, '07 From seattle Currently Offline Reputation: 4 (100%) |
The cracks can be very small and can mostlly be seen when you take it out. When i replaced my cv boots on my t-100 i just replaced the whole joint.
Mar 23, 2008 - 9:34 PM |
Enthusiast Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) |
change it mines like that right now, its clucking and its annonying
-------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
Mar 23, 2008 - 9:55 PM |
How do I change the boot/joint out? Is it a hard job? How would I know if the joint need to be changed aswell?
Is this what I should use? http://www.celicatech.com/imagearchive/bgb...afts%202.2L.pdf EDIT: So after doing a bit of searching it seems it would be easier to replace the entire axle shaft, rather than just the boot. By doing this, it should also ensure there isn't (or shouldn't be) any problems with the joint itself...Would an axle shaft include both halves (inner and outer). My question now is which axle part would I need? The chassis is a 98 convertible, while the tranny is a E153. I'm not 100% sure what sort of axles are currently installed, but it should be E153 inner axles and st185 outers, with a custom spacer from Jamasco. Would someone be able to tell me what exactly the inner and outer axles are, and where the inner becomes/joins with the outer. Is the inner axle the piece that goes from the transmission to just under the alt belt, has the spacer attached to it, and is attached to the centre driveshaft by 6 bolts. And is the outer the piece that is "angled" and goes from the inner to the steering knuckle? Here is a link to pics of my spacer and axles as well as info from the PO regarding the actual axles in the car. http://www.6gc.net/forums/index.php?showto...lution&st=0 This post has been edited by 6gsillyca: Mar 24, 2008 - 1:52 AM |
Mar 25, 2008 - 11:39 PM |
Enthusiast Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
I wouldn't bother replacing the axle since you caught the issue early on.
All-trac boot kit for right hand side CV P/N: 04438-20050 $34 from 1sttoyotaparts.com. That'll be the most cost effective fix unless you can get a boot repair kit from your local parts store cheaper. -------------------- Project ST204.5 99.88946% complete... |
Mar 26, 2008 - 12:27 AM |
I was most likely going to replace the entire axle regardless, as it has sat like that all winter, no doubt accumulating moisture within the boot, and replacing the entire axle is *almost* less work than just the boot itself. Plus I don't need to worry about the condition of the axle, shipping, customs, repacking the cv joints etc....
Unless there is something I am missing, where it would be better for me (cost of the parts aside) to just replace the boot itself. If that is the case, please post up (and why) This post has been edited by 6gsillyca: Mar 26, 2008 - 12:28 AM |
Mar 26, 2008 - 7:33 AM |
You can't just buy a new axle for this application. You need a hybrid axle of MR2 Turbo inners and ST185 outers. You'll have to disassemble both axles and re-combine them to make one new axle including the spacer from your old axle. IMHO that's a lot more work since you could just pull the axle shaft out of the hub and replace the boot without the need to remove the whole axle from the car. Much easier/cheaper.
Mar 26, 2008 - 10:49 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Also can't you get those replacement boots from any auto parts store that have it cut in half with set screws to seal it back up. This enables you to change the boot and repack the grease without removing the axle from the hub or diffy.
You guys seen these things? Are there drawbacks [like they come apart on you or don't seal right etc.]? EDIT: Here is what I'm talking about: http://www.autozone.com/az/cds/en_us/09008...irInfoPages.htm The picture sux as it doesn't show the split but it does talk about it and explain it better than I can. This post has been edited by DEATH: Mar 26, 2008 - 10:55 AM -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Mar 26, 2008 - 10:58 AM |
QUOTE(alltracman78 @ Mar 23, 2008 - 9:10 PM) [snapback]657121[/snapback] Before you replace the boot, check the outer clamp [if there's even a clamp on there]. It looks like the grease is coming from there and not a split boot. ^i'm with this opinion, looks like you don't even have a clamp there |
Mar 26, 2008 - 10:59 AM |
Well I was wondering about the hybrid axle issue so I asked around in the F/I forum and was told that I could leave the inner w/ the spacer attached to the car. I would need to remove the outer where the 6 hex head bolts are and 3 bolts attaching it to the balljoint, and it would be a straight swap with a new reman st185 axle from there.
Please let me know if that is correct or not http://www.6gc.net/forums/index.php?showtopic=57036 When I get another day off I will jack the car up and clean as much grease out as I can. I am not sure about the clamp and have not had a chance to check. I noticed the grase other day as I was cleaning up, but didn't have much time to do anything so I just snapped a few pics and posted. In the event that it is just a missing clamp, should I still need to worry about moisture inside the boot? I just don't want to take the easy way out and just change the boot, and find out in a month that my cv is bad and need to re-do it all over again... This post has been edited by 6gsillyca: Mar 26, 2008 - 11:18 AM |
Mar 26, 2008 - 8:31 PM |
unless the axle is making noise all you need to do is....
1. get a CV boot clamp 2. some axle grease 3. some gloves 4. some kind of pick now, push the boot back from the part its on where the clamp is missing, look for any debris, drops of water, metal flakes. if there are none then pack it back up with some axle grease. dont pack it completely full, just abotu 1/3 to 1/2 or what looks like as much that came out. push the boot back, install the new clamp, clean it up nice and dry, and you should be good to go. -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 1:02 PM |
