Enthusiast ![]() Joined Feb 21, '08 From Saint John, NB Currently Offline Reputation: 0 (0%) ![]() |
well i put my rims on this weekend and now i have a really bad wiggle at bumps and even just randomly down the highway...the car did this before with the steel wheels on but not so badly, i figured it was just my tires that were garbage :S but now its worse, sway bar links? what other options could this be..theres no noise it just wiggles the car almost like hittin a patch of ice sorta feel
-------------------- 94 Celica GT Hatchback 5spd
89 Nissan 240sx coupe 5spd -RIP 87 BMW 325 2dr 5spd - SOLD- Gone but never forgotten |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) ![]() |
check your ball joints..this will cause the car to be taken from ya sometimes and also your tie rods check for play in em. and then go get an alignment
This post has been edited by rjbibeau: Mar 23, 2008 - 9:49 PM -------------------- ![]() |
the whole front end is very tight and stiff , also the car drives very straight, almost seems the wiggle comes from the rear end of the car :S
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
is it the sway bushings or the endlinks, tie rods, wheel hub is loose, etc.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
bad bearing......or you need balancing??? or something is bent???
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Your thrust angle is probably off.
Get a 4 wheel alignment. -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
^x2, and get the wheels balanced while you're at it.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) ![]() |
Jack up your rear, hold the tires at 9 and 3 o'clock, and wiggle them (like you were trying to manually steer them), if you have 1-2mm looseness there you might need some new control arms.
Exactly what you are describing happend to me on my 5th gen. -------------------- ![]() -Rémy 02 SiR, 08 250R |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) ![]() |
Even though it sounds stupid; Check your tires...
-------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Lo-Fi Version | Time is now: February 21st, 2025 - 9:13 AM |
