> Please Help, which one
post Mar 25, 2008 - 6:25 PM
6G96GT
Joined Jan 20, '08
From East Coast
Guys, so I am now interested in the 3SGE engine for my 1996 Celica GT (5sfe). Which gen should I get...the 2nd gen or 3rd gen?
Here's the BIG QUESTION...if I get one of these engines for a swap...is there any "modifications" I would need to do to either the tranny or anything else? AND Is it a direct fit bolt on swap?
THANKS!
Replies (1 - 2)
post Mar 25, 2008 - 6:58 PM
QUOTE(6G96GT @ Mar 25, 2008 - 6:25 PM) [snapback]657913[/snapback]
THANKS!
Feasible and Non-Feasible Engine Swaps - What you can and cant swap into your
You will prolly get most help from stickies. Also, no need for another thread, you could have kept your first thread alive. As a friendly suggestion wink.gif
2. 3S-GE - This engine is another engine that comes standard in many Celicas, including the sixth generation Celica ST202 and ST203(Which, sadly, aren't available in the US.) It's the same 2.0 liter block as the 3S-GTE, but rather than being turbocharged, this engine is naturally aspirated, resulting in less power and less torque. This engine is an option for people who have a Celica and want to do a swap, but they don't want or are not allowed to have a turbocharged car. Even without the turbocharger, this engine is still powerful though. It puts out 177 horsepower and 142 lbs. ft. of torque in the earlier models, and the later models have BEAMS VVT-i(Identified by red valve covers and intake manifolds), resulting in 197 horsepower and 152 lb. ft. of torque. Some people may think that they can swap this engine into their car and later turbocharge it, but this is not a great idea. The internal components on this engine and the 3S-GTE are drastically different, so to make this engine turbo-ready, it would require the use of internal engine parts to strengthen the engine. If you want a turbocharged engine, it'd be much, much easier and cost-effective to simply drop in a 3S-GTE in the first place. This engine will bolt up to any transmission that comes on a ST202, ST203, ST204, or ST205 with no problems, though the stock tranny may not be up to the task of handling high horsepower levels if you have a USDM GT(ST204) for example.
enjoy.
post Mar 27, 2008 - 4:36 AM
6G96GT
Joined Jan 20, '08
From East Coast
Thanks, that's awesome info, I went to that sight and found just about everything I need and now the fellow forumers have pretty much filled in all of the blank spots of confusion I was having.
Lo-Fi Version Time is now: February 19th, 2025 - 11:06 PM
