Enthusiast ![]() ![]() Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) ![]() |
hey some of you know i installed aftermarket seats in my car, so i got a 4 point harness seat belt for my car. im not using my factory seat belt, so my seat belt light is on. what would i have to disconnect to take that sensor off. i took off the wire under my seat which connects to the seat belt but its still on?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
you just have to connect the two wires together.. I did that for a while when I had 4 point harnesses, you just have to complete the circuit.
This post has been edited by Jaws4God: Apr 1, 2008 - 7:32 PM -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
which two wires the one before the connector or the ones after?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) ![]() |
it wont matter, the connector is just and extention really, so either or.
![]() Enthusiast ![]() ![]() ![]() Joined Oct 28, '07 From epworth uk Currently Offline Reputation: 3 (100%) ![]() |
if you do it after the connector you can revert back later easier
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) ![]() |
Or you could just pull the bulb in the GC however your airbag will not go off like that or with your current setup if everything is working right.
-------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) ![]() |
i could be wrong but i'm almost 100% sure the airbag is not run at all through the seat belt indicator.... newer model toyotas do that with the passenger seat but driver seat airbags will always deploy....
Lo-Fi Version | Time is now: February 19th, 2025 - 11:37 PM |
