> suspension and brake upgrade
post Apr 9, 2008 - 6:49 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
after some time of putting up with bad ride handling - i decided to replace and upgrade some parts to help the comfort.
Parts ordered -
1) EBC yellow brake pads -- $165
2) ATE PremiumOne rotors /fronts -- $85
3) Centric OEM quality Rotors / rears - $85
4) Control arms / Genuine Toyota -- $262.74
5) Energy Suspension / Sway Bar Bushings - front and rear - $45
6) Energy Suspension - Coil Spring cushions - $56
7) Stainless Steel Brake Lines / Magnum Performance - Ebay- Still waiting on shipment - $74
8) Royal Purple Synchromax tranny fluid and motor oil - $50
9) TRD Red Stitch steering wheel (already installed - will take picture later once everythings completed) - $650
10) Passenger side Ball Joint - $25 - Genuine Toyota
11) realignment - probably $60
Total so far -- $1495
So far only the control arms have been replaced. Took out the teins SS to clean and put on the cushions. Replaced inner axle boot on passengers side. Cleaned gunks from bottom of engine bay. The brakets for the bushings need to be modified to fit the bolt holes, so I'll finish modifying them tomorrow. Hopefully I'll finish installing everything else tomorrow if girlfriend doesn't come early. I plan on finishing tomorrow then get a realignment Friday. Here in Cleveland, OH most of the streets are horrible, so won't be lowering the celica any time soon, so I won't know how ride comfort will be with it lowered. After spending that much I better get some good results. Then once the brake lines come I'll have to work on it again.
Next would be GT4 conversion and repaint.
Oh - I also have some cusco front top mounts that I will be selling - so i'll post that in the FS section later.
This post has been edited by 2bcelica: Apr 9, 2008 - 6:56 PM
Replies (1 - 9)
post Apr 9, 2008 - 8:25 PM
airfron
Joined Jul 31, '05
From Southern California
if i had only waited a week or so... i just bought some cusco front mounts from japanparts.com
post Apr 10, 2008 - 10:47 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
wow that trd steering wheel is ~50% of what u spent.. must be damn comfortable. wink.gif
nice setup!
post Apr 10, 2008 - 11:02 AM
post Apr 12, 2008 - 5:14 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
I thought the EBC brake pads prevents brake dust...unless that's for Green Stuff only...what's the difference between Green and Yellow EBC brake pads?
This post has been edited by _mikeE: Apr 12, 2008 - 5:15 PM
post Apr 13, 2008 - 2:35 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
this thread is making me excited to order my stuff as well!
エキサイティングカーレーシングチーム!
post Apr 13, 2008 - 3:51 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
wow true ballah status huh?? man your stacked on dough. lucky and good luck on the installs.
post Apr 13, 2008 - 4:19 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
no sway bars?
post Apr 13, 2008 - 4:44 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
QUOTE(_mikeE @ Apr 12, 2008 - 10:14 PM) [snapback]663952[/snapback]
Yellow is Ultra high friction pads for race use but perfectly safe for street use.
Red is Superstreet formula for cars above 200bhp and fastest street driving
Green is Premium street sport pad for cars up to 200bhp. General spirited street driving.
More info can be found at http://www.ebcbrakes.com/automotive.html
post Apr 13, 2008 - 4:53 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
QUOTE(808celica @ Apr 13, 2008 - 8:51 PM) [snapback]664197[/snapback]
thanks - but because I use the celica for work and will be using it for lots of traveling - ride comfort was the priority on my list until I get a 2nd car. I know I could of ordered OEM quality stuff, but I just felt like spoiling myself for once
QUOTE(LewFX @ Apr 13, 2008 - 9:19 PM) [snapback]664202[/snapback]
no sway bars?
I actually checked into that, but was already over budget. Eventually though --
Almost done with the install - would of been done already, but its been rainy and a bit cold - don't have an indoor garage -
Just ordered two new Yokohoma S Drive tires for the rear, so I should be done with everything Wednesday
This post has been edited by 2bcelica: Apr 13, 2008 - 4:56 PM
Lo-Fi Version Time is now: December 3rd, 2024 - 7:42 AM
