> abs code 23 help.plz, abs died
post Apr 15, 2008 - 3:55 PM
tysst202
Joined Apr 15, '08
From suffolk,UK
Hi every1.jst joined the site recently so im a newb.Lol.neway 2 my prob.recently my abs light came on and now abs does not work as it has disabled its self.i have done the diagnotic test with a paperclip.And the code returned was code 23. wich is open or short curcuit in solenoid for the rear right wheel.does nebody have ne idea how 2 fix this?thanks,tys
Replies (1 - 9)
post Apr 15, 2008 - 5:38 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
sounds like an electrical connection issue. Ya gotta find the bad wire. (I think)
post Apr 16, 2008 - 2:03 AM
tysst202
Joined Apr 15, '08
From suffolk,UK
well ive checked the wiring 2 the sensor on the rear and had all the interior trim out.ive checked all the wires in the engine bay and everything seems fine.i thought the grage may have damaged the wire when they lowered the car.bt il keep searching 4 it lol.
post Apr 16, 2008 - 4:57 AM
94TRDcelica
Joined Feb 4, '08
From UK
Have you checked the fuses and relays? And the solenoid as it states?
post Apr 16, 2008 - 5:03 AM
Dell
Joined Feb 4, '07
From Ireland
I left the sensor a bit loose on mine before after doing work and the light kept coming on and going off then. May be something simple like that ?
post Apr 16, 2008 - 12:21 PM
tysst202
Joined Apr 15, '08
From suffolk,UK
i have checkd the sensor and the fuses bt nt sure how 2 test relays or the solenoids or where they r located.
post Apr 16, 2008 - 4:04 PM
GriffGirl
Joined Feb 7, '07
If you're checking the wiring, are you using a voltmeter? I believe you can use it to check the solenoid and at least the wiring going to the sensor.
post Apr 16, 2008 - 4:59 PM
alltracman78
Joined Aug 9, '06
From Ma
The solenoid is inside the ABS actuator [box with all the brake lines in your engine bay].
The solenoids are what physically control where brake pressure goes.
Could be wiring, but most likely the solenoid is bad, which means you have to replace the actuator.
Which is a lot of cash, and a bit of a PITA [bleeding ABS lines sucks, and IIRC the actuator is held on by 5 sided bolts, so a normal socket set won't work].
post Apr 19, 2008 - 1:44 PM
tysst202
Joined Apr 15, '08
From suffolk,UK
i have now got a second hand abs unit.so cud ne1 tell me how hard is it 2 change and ne hints or tips 4 doing it.
post Apr 23, 2008 - 10:30 AM
Paul_Celica_GT
Joined May 20, '06
From Netherlands
Remove brake fluid of all calipers (release the bleed bolts and hamer the brakes panel till it feels flat). Loosen the 5 brake lines, remove the connectors and unbolt the bracket. Mounting is the reverse of removal. Bleed the brakes as good as you can, and/or drive to a garage and have them do it.
This post has been edited by Paul_Celica_GT: Apr 23, 2008 - 10:30 AM
Converted JDM '98 GT-Four to LHD, check my site: Celica GT.nl
Lo-Fi Version Time is now: January 11th, 2025 - 2:52 PM
