> Lowering springs: how much difference?
post Apr 17, 2008 - 7:03 PM
shaunrichard
Joined Mar 13, '08
From Seven Cities, SE Virginia
I am looking at some Tein S-Tech springs. They indicate they lower the front height by 1.5" andd the rear by .9". While I have a pretty good grasp on physics, I am not sure how much of a difference this really makes in performance. Is it really noticeable? For those of you who have lowered your cars, how satisfied are you with the results?
Just curious. Thanks in advance for your replies.
'97 GT Convertible - deep jewel green pearl w/tan top, 5 speed, 240,000 miles and counting Gave up the ghost - being resurrected by perkyshadow
Replies (1 - 19)
post Apr 17, 2008 - 7:12 PM
94TRDcelica
Joined Feb 4, '08
From UK
Yeah you notice it around corners at 100 mph LOL! :-) (Less roll) But its more for looks IMO!
TBH If you do the springs get new shocks too and then you will really notice the ride stiffen up and handle tonnes better!!!! Also a rear and front strut brace all helps!
The most beneficial suspension upgrade though, by far, and I can quote from many other GT4 owners that i have spoken too, the single best upgrade to the suspension you can do on our cars is the bushings!!!! IMHO!
post Apr 17, 2008 - 9:13 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
Would be a good idea to upgrade your shocks too since you're taking everything out.
post Apr 17, 2008 - 10:41 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
hmmmm satisfied????? heck yes
before
after
car sit way lower cuz of my skirts and my old shocks which will be replaced............soon i hope
post Apr 17, 2008 - 11:01 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
It does wonders for looks. And yes because the car is lower the the ground it can take corners better, but you won't feel too much of a difference until you start stiffening up the suspension either with sway bars, struts, bushings or strut bars.
94 Celica gt white (sold)
post Apr 18, 2008 - 3:28 PM
Rusty
Joined Nov 5, '07
From New Zealand
what shocks would you suggest? wouldn't it be cheaper to get shocks & springs as one package?
post Apr 18, 2008 - 8:15 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
You can go with bilstein. I really think if you want to go with stiffer struts with springs you might as well get a set of adjustable coilovers.
post Apr 19, 2008 - 2:44 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
yup yup. full coils will be the best. but if you just want some performance and alot of looks then drop springs and shocks.
post Apr 19, 2008 - 4:08 AM
_mikeE
Joined Sep 28, '07
From Toronto, ON
I got KYB gr2's shocks/struts for my tein lowering springs and some cusco pillowball front mounts for now..no money, i'll probably just get some TRD rear mounts later on.
post Apr 19, 2008 - 8:31 AM
shaunrichard
Joined Mar 13, '08
Okay, so shock (or strut) replacement is strongly recommended. But you guys are talking upgrade, here, not just newer OEM, right? Also, are there specific models that are better than others? Really, what I am shooting for is better performance, but trying to keep costs at a minimum. I don't like the $1G+ pricetag on the coilover systems that I'm seeing and even once I add up struts and springs it's a pretty hefty cash layout, but I just want to make sure it's a necessary cash layout. Knaaamean? Thanks again.
post Apr 19, 2008 - 11:32 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
If you want to save money and want some type of performance, just stick with the gr2s which is an oem replacement but some say is a little stiffer than oem and get the springs of your liking.
post Apr 19, 2008 - 11:42 AM
shaunrichard
Joined Mar 13, '08
Sounds good. I appreciate the info.
post Apr 21, 2008 - 7:31 PM
94TRDcelica
Joined Feb 4, '08
From UK
Yep +1 for KYB GR2's and I recon combine that with the Tein SS tech or Eibach springs for height drop!!!
Further down the line I reccomend doing the busings too! And strut bars are always good!!!
post Apr 21, 2008 - 9:05 PM
shaunrichard
Joined Mar 13, '08
Yeah, I'm looking at strut bars already. But what bushing are you talking about? Also, is there such a thing as a "performance bushing" or do I just need to replace them now and again to keep them functioning optimally. Sorry if I sound like a moron, but I have not done any suspension work up to now, so I need all the help and advice I can get. I promise I'm smart on other stuff, though. Or at the very least, smart-assed! biggrin.gif
post Apr 21, 2008 - 9:18 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
dont feel like a noob. this is after all a forum to learn and ask away..........
yeah what bushings????
but then again when i put my teins on i didnt have bump stops from the start frown.gif
post Apr 21, 2008 - 9:30 PM
terqui
Joined May 23, '06
Bushings are what connect your suspension at certain points. They're usually rubber which is squishy. Polyurethane bushings are basically solid.
Unless you drive on perfect roads i recommend just replacing all bushing that have horizontal movement. Stiff vertical bushings would give a pretty harsh ride.
This post has been edited by terqui: Apr 21, 2008 - 9:30 PM
post Apr 22, 2008 - 6:52 PM
94TRDcelica
Joined Feb 4, '08
From UK
What I mean by bushings is simply replace the olde ones with new ones as rubber can become brittle and fall apart over time, they are in-expensive and wil always improve handling and feel!
In terms of up-rated bushings I'd just replace the rear trailling arms (4bushings).
I get all my suspension stuff from these guys: http://www.fensport.co.uk/products.htm
post Apr 22, 2008 - 8:36 PM
shaunrichard
Joined Mar 13, '08
Thanks for the tip. Good link to have on file.
post Apr 24, 2008 - 3:18 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE(94TRDcelica @ Apr 22, 2008 - 6:52 PM) [snapback]667171[/snapback]
hey i have a questions that one website fensport is the blitz link the only one that you can buy suspension and performance parts from??
post Apr 24, 2008 - 3:30 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
dude your in cali. isnt importrp in cali???
Lo-Fi Version Time is now: January 12th, 2025 - 7:54 AM
